Is it OK to put in N at traffic lights?
10-28-2008, 03:48 PM | #1 |
Rep 863
I've an AT. and at some lights. I know I will sit there for like a min or so and the ground is totally flat. So I just put it in N to relax my leg for not keeping it on the brake.
is that ok to do or bad? or doesn't matter? |
10-28-2008, 03:52 PM | #3 |
Rep 1,691
Drives: 911 992 C2S
shouldn't matter. its fine.
10-28-2008, 03:56 PM | #5 |
Rep 1,828
Drives: 2016 Tesla Model X P90DL
10-28-2008, 04:01 PM | #8 |
Rep 1,828
10-28-2008, 04:34 PM | #9 |
Rep 12,445
...why not just put it in park...
Past: '08 E92 335i|ZPP|ZSP|6AT
Past: '15 Mustang GT|401A|PP|6MT Current: '20 Shelby GT350|6MT |
10-28-2008, 04:47 PM | #11 |
Rep 627
My 2009 E90 manual (covering US 328i and 335i sedans/sport wagons, and Canadian 323i sedans) suggests actually shutting off the engine at "long stoplights or in traffic". They actually state that even if with a stop as short as 4 seconds (yes, that's "four") a fuel savings will result.
Personally, I'd be more worried about wear on the starter, etc, to do this. BMW does have an automatic feature that does this in Europe, but only on the 4-cylinder MT 3-series.... |
10-28-2008, 05:08 PM | #13 | |
World's Foremost Authority
1181
Rep 4,535
Drives: M4 Cab - Cayenne GTS - Jag XK
Location: Upper East Side Manhattan - Boca Raton FL - Lime Rock CT
CA
Drivers Club at Lime Rock - International Motorsports Research Center - Society of Automotive Historians - Madison Avenue Sports Car Driving and Chowder Society (0nly a VP) - BMWCCA - Porsche Club of America - M Gruppe - Polish Race Drivers of America (PDRA) - Glen Club (Watkins Glen International) - Jaguar Club of Southern New England |
10-28-2008, 05:11 PM | #14 | |
Smiling politely
167
Rep 7,931
The difference is that in P, a pin ("paw"?) physically engages in the transmission to lock it and keep it from rolling.
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
10-28-2008, 05:16 PM | #15 | |
1181
Rep 4,535
See Below: A parking pawl is a device fitted to a car's automatic transmission that locks up the transmission. It is engaged when the shift selector is placed in the Park position, which is always the first position (topmost on a column shift, frontmost on a floor shift) in all cars sold in the United States since 1965 (when the order was standardised by the SAE) and in most other vehicles worldwide. The parking pawl locks the transmission's output shaft to the transmission casing by engaging a pawl (a pin) that engages in a notched wheel on the shaft, stopping it (and thus the driven wheels) from turning. Most manufacturers and mechanics do not recommend using the transmission's parking pawl as the sole means of securing a parked vehicle, instead recommending it should be engaged after first applying the vehicle's parking brake. Constant use of the parking pawl only, especially when parking on a steep incline, means that driveline components are kept constantly under stress, and can cause wear and eventual failure of the parking pawl or transmission linkage. The pawl might also fail or break if the vehicle is pushed with sufficient force, if the parking brake is not firmly engaged. Replacement can be an expensive operation since it generally requires removing the transmission from the car. It is also not recommended to use the parking pawl to stop a vehicle in motion. The pawl mechanism is not strong enough to stop a vehicle in motion or may not engage at all. Under that much stress, the pawl may break off in the transmission, leading to costly repairs.
10-28-2008, 05:34 PM | #16 |
Rep 73
I put it in N at longer stops. It's just a habit because I feel like it's less wear to the components.
Regarding the rear-ending situation, I'm not sure I concur with your logic. Why brake? When in neutral the car can roll thus converting some of the impact energy into motion, thus lessening the damage. If you brake more of the impact is spent on destroying the car.
"Good morning - Look at the valedictorian, scared of the future while I hop in the DeLorean"
10-28-2008, 05:52 PM | #17 |
craptastic
19
Rep 281
re: no brake
I suppose if you're first @ the intersection, you may not want to get pushed into the middle of the intersection and get plowed over by a semi.
On the other hand, if you have a car in front of you, if you *know* that you're about to get rear ended, the best thing you can do is get right on the bumper of the person in front of you. It will greatly lessen the damage to your car. |
10-28-2008, 06:20 PM | #18 |
Rep 863
you guys are funny. how did this thread get into the MT discussion?
So, in conclusion. assuming, normal day by day, don't expect be rear ended and there are cars in front of me at the lights. It's GOOD to put it in N? but even in case of rear ended. I would imagine my car will transfer the momentum/force to the car in front of me, which may result in less damage to my car/me. But I am not worrying about this though. I was just wondering if any damage to the AT by put in N |
10-28-2008, 06:20 PM | #19 | |
Rep 12,445
10-28-2008, 06:54 PM | #20 |
Rep 1,325
10-28-2008, 07:24 PM | #22 |
Rep 863
yeah. somehow I thought it would be bad to the AT if put in P (compare to harmless N). I guess I was wrong.
