BMW X5
      04-18-2021, 10:09 PM   #1
deneed4spd
deneed4spd's Avatar
Drives: F87 M2 OG<E90 328i<E36 328i
Front Center Jackpoint
My quick jack even with an extension won't fit the G05 side jack points. Was wondering if anyhow knows if there is a center jack point in front of the car so I can jack up and use the side ones with jack stands.
      04-19-2021, 11:38 AM   #2
denaliman
denaliman's Avatar
Drives: 2021 BMW X6M Competition
2013 X6M  [0.00]
So Which quickjack do you have? I have the BL7000 EXT. It was ok for my E71, but will not fit between the jack points for the F96. Easy fix, you will need to use it across the frame, left side to right side. No problem it was designed to do this and quickjack confirmed this. I have used it this way several times and there is absolutely no stability issues. I hope this helps.
_____________________________________
2021 X6M Competition, 2021 Audi SQ5 Technik, 2013 Audi S4
ladra17.50
admranger2984.50
      04-19-2021, 10:24 PM   #3
deneed4spd
deneed4spd's Avatar
I have the BL-5000SLX. It has 60 inch spread. I think there is an extension to get it to 66 inch spread which is equal to your 7000 lift. So I'm assuming 66 inches allows you to fit the jack from side to side?
      04-19-2021, 11:37 PM   #4
denaliman
denaliman's Avatar
2013 X6M  [0.00]
Yes it allows me to fit side to side with a few inches to spare. I think the L/R spread is about 62-63". As you can see I also use the truck adapters.
xbimmers
