04-23-2021, 06:10 PM | #1 |
Rep 112
Brake Squeaks In My G80
I love my G80 but god I hate when my brakes squeak lol, I have 700 miles on it now and I thought it was only the Carbon Ceramics that did that. Is anyone else noticing this?
04-23-2021, 06:22 PM | #2 |
1949
Rep 1,908
Drives: E92 M3
None yet. Has it been through rain yet?
------ Mine is 500 miles in, several days of rain and cold temperatures (40F to 50F), but still no squealing. Last edited by Ximian; 04-26-2021 at 03:54 PM.. |
04-23-2021, 06:42 PM | #4 |
Rep 455
Go burnish them in and see what happens. Some noise is to be expected out of a high performance brake setup.
Current: '23 Ford Raptor
Incoming: '24 G87 M2 - BG/6spd BMW Past Rides: 2023 G80 Comp, 2023 G80 xDrive, 2021 M3 Comp, 2020 M340i, 2019 540i, 2016 M4, 2016 535i, 2008 545i |
04-23-2021, 06:49 PM | #5 |
Rep 57
My M-Compound brakes still squeak on my 2021 M2C 7 months after delivery...it's pretty common. I'd expect the carbon ceramics to squeak even more. You can have them look at it, but I'd put money on the table that it's totally normal.
04-23-2021, 07:42 PM | #6 |
Rep 1,360
Mine G80 M3 squeaked like crazy and after the 1st track day, no squeak.
Btw, this is the 1st M3 that did not need Pagid brake pads to survive a few sessions. Every M3 before this model without ceramics SUCKED at the track without a pad upgrade at a minimum. |
04-24-2021, 11:19 AM | #7 |
Rep 171
My squeaks but not all the time, I only have 420 miles on the car. This is not unusual for new brake pads from what I have read. Good to hear that it was gone after the first track day, I have a track day scheduled for early June.
05-07-2021, 04:40 PM | #8 |
///MFlight Member
455
Rep 247
I have about 1600 miles on mine and they squeak too but not all the time. Seems like when I apply light pressure for slow stops the brakes squeak but when I apply heavy force at much faster speeds I don't hear any squeaks. I also noticed that after I wash my wheels and spray out the wheels and the rotors, I don't get any squeaks.
05-07-2021, 04:52 PM | #9 |
Rep 246
I followed my usual bedding in procedure for new brakes and the squealing went away but has returned albeit much less. I didn’t have enough open road to do it 100% so I plan on doing it again.
https://brakeperformance.com/bedding-in-rotors.php |
05-09-2021, 07:14 PM | #11 |
Rep 143
Mine was doing it then I went to Mexico and braked really hard after 😀
Limegrntaln13560.50 |
05-17-2021, 03:15 PM | #12 |
Rep 178
mine are horrid I can't have the window open its so loud I expected some as its a high performance car but good god its bad its probably the brake dust build up and they are a high metallic compound but its honestly unacceptable to me how bad it is for steel brakes the only option is probably clean them all the time or change the pads to something less aggressive
05-18-2021, 10:44 AM | #14 |
Rep 246
As I mentioned above give this a try. It will resolve the issue and make the pads and rotors last longer.
G80 M3 manual
Notable-Giulia QV, MK7 Golf R man,991 Turbo,CTS-V3, CTS-V2 man Speed INC. build, E60 M5 SMG, E46 M3 ZCP man, E39 M5, E39 540 man, Porsche Cayenne Turbo EVOMS build, EVO X AMS build, Blobeye STI, 83’ RX-7 built by Alan Jackson racing, Volvo 164e |
06-07-2021, 07:35 PM | #15 |
Rep 3
I am experiencing the same issue. Dealer said they are hearing this a lot with the new M3 and M4. In short, they said since the high performance brakes create more dust, the brakes will squeak at lower speeds due to that dust. Was not thrilled with their response to say the least.
06-11-2021, 03:44 PM | #16 | |
Rep 4
I did the bedding in procedures in the PDF above, and the squeaking went away. Probably could have done a little less, along the lines of the posted G80 manual. Thank you. |
06-11-2021, 05:37 PM | #17 | ||
The Dad
89
Rep 178
Drives: M4 G82 Competition
The Dad was here ?
07-08-2021, 08:47 PM | #18 |
Rep 7,002
Drives: 2022 DG/BLk xDrive M4C Wk 34
Just like any other car that has Brembos, you need to take a few trips to Mexico for some 150-0 runs. Or just take a few rips down the 1/4 mile track. They'll be fine after that. If you drive Ms. Daisy with it, they will always be loud. I cracked up when I read about the BMW CCB lawsuit. Clearly, these people don't use 3/4 of the speedo.
The only time my C7 ever did it, was during the engine break-in period. After that, a few brake stabs and they never make noise. |
maelfyn156.50 |
08-19-2021, 08:10 PM | #19 |
Rep 1
Drives: BMWM3C,F-typeS,LexRCF,Panamera
Unacceptable‼️
I have over 4K miles on my M3C and the brake squeal is terrible‼️
I understand why it happens but that does NOT make it right or acceptable…..It’s painful to roll up in a M3 Competition beast of a car when every dog at the corner you are pulling up to looks like its ears and head are gonna explode from the screeching noise‼️ |
Kansr164.50 Fortyounces31.50 |
10-06-2021, 08:44 AM | #20 |
Rep 980
I had this happen too for two months. I got pissed off made some hard stops and it's gone. Stop babying the brakes… that's what I was told… lol it worked
2008 E60 550 ? Alpine White // RPI
2011 E90 M3 Competition // Alpine White // ESS // RPI // 20" BBS LM's, blah blah 2021 G80 M3 Competition // Brooklyn Grey // KW Suspension // 12mm Spacers all around // Resonator Delete |
10-06-2021, 09:31 PM | #21 |
Rep 246
I've bed the brakes in at least three times and also done some aggressive breaking from high speed and they still squeal like a pig. I think it's just nature of the beast.
G80 M3 manual
M3LISSA808.50 |
10-07-2021, 08:53 AM | #22 | |
Rep 980
translux481.00 |
