05-02-2021, 03:49 PM | #1 |
LCI'd
260
Rep 822
Rear brake pad how to
Hi,
anyone have a how to on replacing the rear pads? What tool (ideally phone based) can I use to rewind the pistons on the parking brake? What pads would you recommend? Thank you. |
05-15-2021, 05:17 PM | #2 | |
Rep 1,328
As far as electronic tools, I have failed at finding an inexpensive one so far. The best tool is mechanical that I've found... https://www.amazon.com/OrionMotorTec...09120692&psc=1 While the BMW M-sport pads are good (except for track endurance), they squeak wayyyyy too much. I'd recommend the following pad. I've used it. Works well, not squeaky.... https://racingbrake.com/pd2059-391 I can help you if you need it. It's pretty much a standard replacement from grandma's 528i except for the electronic parking brake, which retracts mechanically with the proper tool (above). Shawn |
05-16-2021, 02:55 PM | #3 | |
Perennial PFC
338
Rep 1,275
05-19-2021, 03:12 PM | #4 |
Rep 7,161
Drives: F90 M5 / F15 50i
retracting the brake pad is pretty easy to do without any tools. I simply put a tube and bottle on the brake bleed line, crack it open and then when i loosen the caliper carrier, i simply apply pressure against the rotor with the brake pad and it compresses the piston. These calipers are new enough they should move pretty easy. This is what i do on every sliding caliper ive owned with no issues. this also won't lose enough fluid to be an issue if you dont have any extra.
'07 Yamaha R1 (sold)
'06 C55 AMG (sold) ‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe '14 X5 50i (wife’s now) |
05-22-2021, 03:40 PM | #5 | |
Rep 1,328
Your approach WILL work on the fronts as they have no parking brake attachment, and work just like any other fixed multipiston brake. Shawn |
05-22-2021, 03:45 PM | #6 | |
Rep 52
2019 BMW M5
2016 Dodge Charger HC 2005 E55 AMG Wagon |
05-22-2021, 04:05 PM | #7 |
Rep 1,328
05-22-2021, 06:52 PM | #8 |
Perennial PFC
338
Rep 1,275
05-22-2021, 07:43 PM | #9 |
Rep 1,328
05-22-2021, 11:18 PM | #10 | |
Rep 52
2019 BMW M5
05-29-2021, 08:31 PM | #12 |
Rep 1,328
07-05-2021, 10:54 PM | #13 |
Rep 52
Thanks to all for this thread. I installed rear brakes myself today, very easy - if you have all the tools suggested in this thread and video.
I used R1 rear brakes. I will post post pics of the difference between those R1 pads and OEM. But, my brake noise is gone.
2019 BMW M5
07-06-2021, 08:53 PM | #14 | ||
Rep 7,161
07-11-2021, 08:39 AM | #15 |
Rep 501
The rears are actually screwed back into the caliper, not simply pushed back like most other BMW brakes.
07-13-2021, 02:00 PM | #16 |
Rep 7,161
Ok. But the pad doesn't twist. Does that tool attach to the pad or do you have to remove the pad and attach to the piston?
07-13-2021, 07:53 PM | #17 |
Perennial PFC
338
Rep 1,275
shawnhayes1838.50 |
07-13-2021, 07:54 PM | #18 | |
Rep 52
For our rear brakes, you use a round no. 8 disk that fits onto the brake piston. As you turn your tool, it turns the disk, which turns the brake piston inward.
2019 BMW M5
shawnhayes1838.50 |
07-14-2021, 02:48 PM | #19 |
Rep 52
shawnhayes, thanks for providing info on that brake tool. It made the install that much easier and quicker!
2019 BMW M5
shawnhayes1838.50 |
08-03-2021, 10:27 PM | #20 | |
Rep 1,328
I hope you enjoy the car. Shawn |
08-03-2021, 10:37 PM | #21 | |
Rep 1,328
I tried to use a normal piston tool to "push" the piston back in. Being an old hand at doing this, there was WAY too much resistance that I was comfortable with. All I had to do was look up bavarian autosports video on how to do it to understand that if I had followed through with what you said, the bill would have been EPIC. But here's what you have to do if you don't have the mechanical "winder" tool (like shown above) or an electronic tool to retract them electrically (this should be possible). But, for posterities sake: Shawn |
03-09-2023, 01:38 PM | #22 |
Rep 235
Drives: 2022 M5C /// 2023 XDrive40i
Unlike the rear brake pads, can anyone shed some light as to why the BMW factory manual states several times to NOT use paste/lubricant on the pads or the retaining hardware for the fronts?
Is there some special coating on the front retaining clips?
Reventon Splitter /// Reventon Diffuser /// Addlights M Door LEDs /// Dinan Inlets /// Gentleman's Switch /// Paddleshifterz With Piano Black Steering Wheel Trim /// Charcoal Filter Delete /// Piano Black Side Skirts /// Funk Motorsports Turbo Blankets
