05-06-2021, 04:20 PM | #1 |
Rep 581
LED door projector cut off
I have seen several posts where OEM BMW LED Door Projectors are successfully fit on the X7. I know about trimming the body to fit the projector. I was hesitating initially and finally decided to go for it.
I just got the OEM projectors(63312468386) and I even double checked with the shop before purchasing and they said it is compatible with the X7. I finally cut the body and pushed it in and see that it is getting cut off. How do you guys fit it in X7 without the logo getting cut off? |
05-06-2021, 04:33 PM | #3 |
Rep 581
05-06-2021, 05:27 PM | #4 |
Rep 3,479
I've seen this result in another post about the projectors. Unfortunately, mine didn't have this result when r33_RGSport installed mine, so I don't know what to tell you. Mine turned out fine.
The issue seems to be not with the projector and the installation bracket itself, but that the edge of your light beam is catching the bottom of the door lip (where the reflection bit is, in your door picture above). Could the projector be tilted inwards towards the door, because of the tightness internal to the installation bracket? I know r33_RGSport had to grind some of the door internal to the bracket to get my projector to fit.
Cross-continent road trip journal from BMW PCD to Alaska in new X7 M50i in this thread HERE!
New EVEN BIGGER road trip in X5 from BMW PCD to Alaska NOW ONGOING LIVE IN THIS THREAD! Wilderness road trip journal to Eastern Alaska in this thread And road trip journal to Denali and the Arctic Circle here in this thread! |
r33_RGSport13108.50 |
05-06-2021, 05:36 PM | #5 |
Rep 3,361
05-06-2021, 06:39 PM | #6 | |
Rep 581
05-06-2021, 06:58 PM | #7 |
Rep 5,350
It’s those models of projectors. I used the older oem clear plastic projectors and there was no issues at all for all 4 doors. (Part# 63312414105)
https://www.ebay.com/itm/22444113702...wAAOSwEzxYbaHx |
djbonsu113.00 |
05-06-2021, 07:37 PM | #8 | |
Rep 581
05-07-2021, 01:21 AM | #9 |
Rep 1,791
I would think the bigger concern is whether or not the original projectors will still fit since you had to trim the hole to get the new ones in.
Your situation is the reason I decided not to even bother installing them until BMW comes out with ones that are specifically designed for the X7 and require no cutting/trimming. Just pull the original ones out and pop in the new ones. There shouldn't be any need for modifications if they are designed for X7. |
05-07-2021, 03:37 AM | #10 | |
Rep 581
2. No, I dont think BMW ever will release a X7 specific one. The instructions on this projector explicitly calls to trim out the edges with a blade |
05-07-2021, 10:18 AM | #11 |
Rep 2,012
Drives: 2022 i4 M50
I'd imagine it clashes with the "carpet lights" a bit, right?
Current: 2022 i4 M50 | 2022 G07 X7
Gone: 2020 F92 M8 | 2020 G07 X7 | 2018 F80 M3 | 2017 F15 X5 | 2016 F16 X6 | 2015 F36 4 series GC |
05-07-2021, 10:26 AM | #12 |
Rep 5,350
unfoundnemo1923.00 |
05-07-2021, 11:12 AM | #13 |
Rep 2,012
Drives: 2022 i4 M50
Yeah, I suppose the carpet starts further back than I realized. Works well with the M logo, a bigger BMW logo might be a bit munch for my taste if it's too large and closer.
05-07-2021, 11:16 AM | #14 |
Rep 581
05-07-2021, 02:01 PM | #15 | |
Rep 581
05-07-2021, 02:33 PM | #16 | |
Rep 5,350
They are definitely different than the ones you purchased. The link I supplied above should show you what the clear plastic oem housing looks like. I have installed this model of projectors on everything from a G05, G07 and a M2C. No cutting required. There is a pic in this link of the model I use. https://horizonmotorsport.com/produc...smart_campaign Last edited by MystroX5; 05-07-2021 at 02:40 PM.. |
05-07-2021, 03:13 PM | #17 | |
Rep 581
Which year X7 do you have? All G07s should have the same body design right? Last edited by jonatious; 05-07-2021 at 03:22 PM.. |
05-07-2021, 05:02 PM | #19 |
Rep 581
Thanks, going to pull the trigger and order the one you linked on ebay. The seller has mentioned no returns and also said it is not compatible with my car, which is sounding scary. But hoping to trust that the part worked for many members and going to try
05-07-2021, 05:41 PM | #20 | |
Rep 5,350
https://g05.bimmerpost.com/forums/sh....php?t=1769067 |
05-07-2021, 11:52 PM | #22 | |
Rep 581
