E92 M-Sport Ride Height
10-31-2008, 04:00 AM | #1 |
Rep 21
I recently (last week) had both front Dampers changed on my E92 under warranty to cure a knocking noise when going over speed humps, ever since I am convinced that the front ride height looks wrong......What do you all think?
Also have another problem where the steering wheel is no longer straight when driving on a straight road but i'm sure the dealer can sort that out...... Thanks Miles |
10-31-2008, 04:04 AM | #2 |
Defected to the dark side.....
210
Rep 5,795
Drives: BMW M5 LCi
Looks high at the front?
Sure they are M-sport shocks they fitted?! |
10-31-2008, 04:41 AM | #4 |
Rep 8,093
Definately not right but I guess it doesn't bottom out on speed bumps anymore.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
10-31-2008, 05:00 AM | #5 |
Rep 13,043
Drives: BMW M340I G20
Dampers don't affect ride height, maybe they changed something else.
My old E92 from a simlar angle And on 19's |
10-31-2008, 07:45 AM | #7 |
Rep 1,037
definitely looks like a bit more space in front..maybe you should go back to the dealer/service manager and ask..with the 19's as standard i'm sure it should look lower than this..
You're born, you take shit. You get out in the world, you take more shit. You climb a little higher, you take less shit. Till one day you're up in the rarefied atmosphere and you've forgotten what shit even looks like. Welcome to the layer cake son.
10-31-2008, 01:07 PM | #8 |
Rep 370
When replacing shock absorbers, it takes some miles of driving for them to take their normal height position. It makes the car look sitting higher for a while.
As for the steering wheel, im pretty sure, that after the replacement, the dealer did not take your car for a wheel alighment. |
10-31-2008, 02:06 PM | #9 |
Rep 445
Have you visually checked the new units to see if there is anything causing this, ie 'blocks' which are loacted in the springs for when cars are in transit, which should be removed by the dealer.... wouldn't expect this on a new set of replacement suspension but ya never know... plus, having seen the very same issue on another car (different forum) and it was this reason why the car looked jacked up, its the 1st thing that sprung to mind.
2014 [14] M135i, 3dr, MG, Auto, SP, CP, HS, HK and FBP
Recent Past..... 2011 [61] Abarth 500, Funk White, Leather, H&R 2007 [57] 320d M-Sport Touring Pre 2007 - GT TDI 4MO, Mk4 R32, A3 TQ, A3T, Cupra R and on and on and on..... |
11-01-2008, 06:11 PM | #11 |
Rep 131
I thought I'd throw in that Im having problems with the back wheel levels, my drivers side rear wheel constantly sits with one fingers gap between it and the top sill and the passengers side sits with a comfortable three finger gap, regardless of the camber of the road.
I notice from some of the pictures that your drivers side rear wheels also sit pretty close to the bodywork, I'm on 19s and the fronts have pretty normal spacing (3-4 fingers for each wheel) |
11-01-2008, 06:28 PM | #12 |
Rep 200
Drives: E92 335i M Sport
At certain angles my front passenger also looks high but not as much as yours:
11-04-2008, 07:12 AM | #14 |
Rep 21
Thanks for the replies, car is booked in again next Tuesday for them to check the alignment and the ride height, they are also replacing the Clutch pedal mechanism (it makes weird noises) and changing both seals on the differential output shafts as they are leaking.....
Miles |
