05-25-2021, 06:55 PM | #1 |
Rep 1,298
MPC - stiffer settings
I'm looking for suggestions on how to make the car a bit less bouncy when going over bumps on M Performance Coilovers.
Currently at "track" settings which are Front C4/R7 ; Rear C4/R10 Any other settings people have experimented with for a less bouncy and more stiff ride? Car handles good with little to no body roll, but want less bounce when going over bumps. Shop advised going down 1 more click from the above settings
2024 BMW M4 Competition XDrive - Tanzanite Blue/Kyalami Orange - AST HAS - RaceChip
05-26-2021, 07:06 AM | #2 |
Rep 139
The KW/MPS dampers don’t do well at high, (stiff) compression and rebound settings as the valves aren’t quick enough to react when hitting bumps. This often causes a slow response when hitting bumps at speed, which leads to a poor ride.
Two real options - invest in more expensive coils, or use softer settings. If you’re using the car on bumpy roads/tracks - try reducing the compression and rebound settings. Not just one click - a good few clicks softer. It’s usually better to start soft and then increase stiffer, rather than the other way around. Faster times, especially on bumpy tracks are achieved through compliance; rather than stiffness. I’d recommend 10 clicks open for both rebound and compression and go from there. The ideal setting will vary on the type of road/track you use. One setting definitely doesn’t work on all surfaces. Good luck! |
05-26-2021, 03:56 PM | #3 | |
Rep 1,962
BeePee is running MPS with 18s, so would be a useful person to ask. |
05-26-2021, 04:17 PM | #4 | ||
Rep 1,298
My tires are 275/30 and 295/30 MPS4S
05-27-2021, 04:02 AM | #5 | |
Rep 4,529
Tried track settings on the street and it was a bit firm so backed off the fronts towards street settings and rears, one notch down for B&R settings. Switched to 18" wheels on MPSS 245&265/40/18 then had the car fettled by Center Gravity (CG) - see thread in the link below https://f87.bimmerpost.com/forums/sh....php?t=1633253 Post fettling by CG, my car's damper settings (18" 245/265 MPSS tyres @ 31psi cold) Front axle Rebound 11 clicks open Bump/Compression 7 clicks open Rear axle Rebound 8 clicks open Bump/Compression 6 clicks open Dampers set harder in the rear than the front for 2 reasons:- 1. When assessing compression/suspension travel with all dampers set too full soft, Chris @ CG was amazed at how firm MPC front springs were. Hence, less bump dialed in as springs don't need as much support due to their stiffness. Conversely, less rebound to balance between enough weight transfer, limited body movement and optimising compliance to ensure tyre contact patch consistency. 2. The concept of bumpstops being secondary spring effectively means that they prohibit spring travel/damper stroke which, when c/w ride height, maybe sub-optimal when expecting suspension to remain effective at managing tyre contact patch/compliance. This was the case with my car, in the rear it showed evidence of bumpstop contact. Bumpstops trimmed down by 10mm. With dampers set too full soft, rear MPC spring rates are less than the front. Therefore, rear needs more support from the dampers ie higher bump setting and more rebound to re-settle springs quicker. For trackdays, if need be, increase rebound stiffness in 2 click increments F&R and gauge how the car feels. Works very well. BP
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
McLaren720s1512.50 |
06-03-2021, 05:05 PM | #6 | ||
Rep 1,298
My local track is pretty bumpy so hoping it will help settle the car better over them Do you think I should increase rebound for both front and rear from the settings you recommended? I also want to minimize body roll and don't want the car too soft
06-04-2021, 01:54 AM | #7 | |
Rep 4,529
If wanting less roll you may want to increase bump/compression too but I'd try it 1st with B/C settings as-is. If track is bumpy and lesser sidewall of 19" wheel/tyre combo, dialling in more damper stiffness may mean tyre contact patch becomes too variable and grip level reduces accordingly.
McLaren720s1512.50 M2C_PLUS1774.00 |
06-19-2021, 07:16 PM | #9 | |
Rep 1,298
Went for a spirited drive in the mountains and the car felt fantastic! These were mostly high speed turns with occasional bumps and the car felt smooth, planted, never destabilized with good subtle feel of weight transfer. No more jarring and very stiff ride for no reason! Can't comment on behavior in tight corners yet until I can push the car hard at the track next month but so far I am very pleased with there new settings! Thanks. Thanks!
Bee Pee1787.50 |
