BIMMERPOST Universal Forums Cosmetic Care & Detailing (PPF/Wash/Wax/Detailing/Restoration/Repairs) Applying Ceramic at home
      05-25-2021, 09:25 PM   #1
barryc365
Drives: BMWM3
Has anyone done ceramic themselves? It doesn't look like rocket science. Any advice appreciated.
I've watched some videos myself and doing it on a new car is obviously a lot easier than one that needs a bunch of correction. Thoughts?
      05-25-2021, 10:34 PM   #2
Foggins
Restless
Drives: M2C
Yes I have done it a bunch and you’re right, it’s not rocket science. I use CQuartz UK, I like the ease of application and efficacy. Here is my general routine:
- wash the car
- iron remover sprayed on car, rinse
- light clay mitt with lubrication
- single stage polish just to drive paint clarity and take out minor scratches
- IPA wipe down to thoroughly clean paint
- apply coating in small section, wait for it to flash, and remove with a couple of MF towels
Once full car is done, don’t get wet for several hours.
Enjoy!!
      05-26-2021, 06:24 AM   #3
barryc365
Drives: BMWM3
Thank you.
Can I apply it to a new car without machine polishing? The paint looks great to my eyes or is that a crucial step?
      05-26-2021, 06:39 AM   #4
SickGTR
Drives: 1000whpGTR/ F-82 YAS
Originally Posted by barryc365 View Post
Thank you.
Yes. Just remember, any swirls or imperfections will be "locked" in. I would at least clay bar. Get the Meguires rubber one. It works pretty good and is super easy to use. You don't need a special lubricant. Just mix extra soap when washing, wash a small section then use the soapy water and run the bar over that area. Smooth as silk. Good luck
      05-26-2021, 08:01 AM   #5
barryc365
Drives: BMWM3
Thank you.
Thanks. The paint looks awesome to my eyes anyway so a good clay/decontamination should do the trick.
Now getting the time to do this all is the next hurdle
      05-26-2021, 09:23 AM   #6
SickGTR
It really should not take you long to do. The ceramic flashes off in 1-2 minutes. So wash/clay/ dry and ceramic. Good luck
      05-27-2021, 12:06 PM   #7
Nettles
Nettles's Avatar
838
Drives: M340i
Claying always induces some level of swirls/imperfections. Pretty much everyone recommends at least clay/iron remover/light polish/ipa wipe down before applying a coating. Light polish is probably the most debatable, but it for sure helps. Don’t skip the rest.
Go for a user friendly coating like Gyeon MOHS. Maintenance is always key for getting the best durability out of a coating. No it’s not made of unicorn tears to prevent scratches and other damages. It’s meant to make it look good, give protection from the elements longer than wax/sealants, and to make washing an easier process. Every 2-4 months reapply a topper to boost the coating. I believe Amazon sells MOHS/Cure combo for $100.
FYI clay is not rubber.
      05-27-2021, 08:41 PM   #8
SickGTR
Yo chief, for a new car, that rubber will be just fine. I assume you haven't tried it? I use it all the time now and it's great for a beginner/mediocre detailer. You can even use that Not rubber clay over your clear wrap. Something I do as well. Happy ceramic-ing
