2010 2011 BMW 5 Series Forum F10 Ceramic SAT Shifter Retrofit? |
06-02-2021, 03:08 AM | #1 |
Rep 62
I have a 2011 535i. I wanted to change out my shifter to the ceramic sport shifter and found the part number that should fit my car. Found a ceramic sport shifter on eBay that has the matching part number so I bought it. When the part arrives I open up my center console and attempt to switch the shifter only to discover the ceramic sport shifter has 10 pins and the stock one has 8 pins.
I tried to do more research and it seems that the regular shifter has 8 pins and the sport ones have 10 pins. I thought this switching shifters was a plug and play. Do I need to buy a 10 pin socket housing? |
06-02-2021, 09:57 AM | #2 |
Rep 2,595
Yep, BMW switched to a 10 pin connector in 03/2012. Wiring stayed the same, but the wire positions within the housing changed. You'll need the 10 pin housing (P/N: 61139132577) and then transfer the pins over to their proper locations.
Wiring: https://f30.bimmerpost.com/forums/sh...08&postcount=5 Guide is off a F30, but it should be the same. I'll pull my console and double check if the posted wiring configuration doesn't work The slightly confusing part is the green and red wires. Pay attention to those. There's a mostly red one with a green stripe, and a mostly green one with a red stripe.
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial Last edited by Unspec; 06-03-2021 at 11:36 AM.. |
Surly73543.50 |
06-03-2021, 10:30 AM | #4 | |
Rep 1,876
Unspec1311.50 |
06-03-2021, 11:48 AM | #5 | ||
Rep 2,595
And to confirm, it does look like a simple repinning, corroborated by newTIS (see below). These are the actual wiring diagrams for the F10. I wonder if it's possible to put a 8 pin shifter in a 10pin car. I can't see why anyone would do that though lol. Also, F30 shifters will not work in a F10, and vice versa.
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial Last edited by Unspec; 06-03-2021 at 11:58 AM.. |
06-09-2021, 09:13 AM | #7 |
Rep 2,595
NICE. Guess it's officially verified that it's just a super simple repin.
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial |
06-29-2021, 11:13 AM | #8 |
Rep 6
Hi,
I have a 2013 F11 535d with the small Idrive knob, could anyone confirm if it is 1 to 1 fit in my case? I suppouse some coding is needed to activate the touch functions. |
06-30-2021, 07:50 AM | #9 |
Rep 1,363
You will need to install a touch controller module, replace the iDrive controller and then flash the head unit
