2010 2011 BMW 5 Series Forum F10 Stuck at ZGW2 flashing - advice needed? |
06-07-2021, 02:19 PM | #1 |
Rep 7
Hi everyone, I am trying to flash ZGW2 High to enable can3 function. My car is before facelift.
- I edited basevariant zgw → zgw2 and - modified zeitkriterium and typeschlussel to LCI values And then tried many Istep combinations but it always either shows no update available, or if update available then hwel is red. From my knowledge I shouldnt flash with red hwel? So I am stuck. How can I update ZGW2 high, do i try to flash anyway despite red hwel? If anyone has any thoughts or ideas, please share. |
06-08-2021, 11:49 AM | #2 |
Rep 953
This might be a tough one. I would recommend first trying to flash back to stock FW. Ideally, I'd recommend getting a used ZGW -8sk and use that with your car to get CAN3 enabled, (assuming you're doing this for LED retrofit since that's the only module/s that use CAN3 on F10 platform ((besides night vision dynamic spot lighting I believe))
06-08-2021, 04:10 PM | #3 |
Rep 7
I read many of your posts in other coding threads, thank you for contribution.
You are correct I am trying to retrofit LCI LED headlights. I think ZGW2-8SK is not an option for me because it doesnt have MOST connection, which I need because of CIC? Also I dont understand what do you mean by trying to flash back to stock FW? Do you mean FA? |
06-08-2021, 06:23 PM | #4 |
Rep 953
OK, I was able to get the High Plus ZGW also to work. That ZGW came out of a 650i 2013 and I had flashed it with option 552 in FA in place of the xenon option.
Assuming of course you are starting with a ZGW High or ZGW High Plus (black ZGW) instead of one in a silver case... |
06-08-2021, 06:30 PM | #5 |
Rep 953
06-10-2021, 02:53 AM | #7 | |
Rep 7
This is my current ZGW module, ZGW-02 High version which should support newer software from my understanding. I ll try to send you my email in pm. |
06-11-2021, 05:09 PM | #8 | ||
Rep 953
06-15-2021, 11:56 AM | #9 |
Rep 7
I managed to flash my ZGW successfully with warnings, using this guide
But now my CIC is dead, and still there is no communication between lci headlights and car even with CAN3 enabled. |
