BMW 5-Series (G30) Forum DIY Discussions / Guides / Instructions G-series 6WB Virginization.
      06-18-2021, 11:20 AM   #1
chuddism
Drives: 328xi
Hello All,
Been doing a lot of research on the 6WB retrofit for my G-series.
At this time i cannot find anyone that does the virginization for the 6WB from the G-series and I'm wondering if I'm missing anything.
Am I stuck buying a completely brand new cluster to avoid the tamper dot post coding? or if i buy a cluster with confirmed lower mileage than my car will that be fine (cluster adjusting mileage upward to match the car?
Thanks all.
      06-18-2021, 02:26 PM   #2
beerman80
Drives: BMW M550i
Originally Posted by chuddism View Post
Hello All,
Thanks all.
I have been looking into this as well and when I inquired about using a used 6WB this is what I was told:
"If 6WB is used, it must have VIN and Mileage blanked. I cannot do it as EEPROM must be desoldered and either blanked, or replaced. Best to buy new one for sure."
Let me know if you find out anything different.
      06-18-2021, 03:27 PM   #3
chuddism
Drives: 328xi
yeah that lines up with what i've been reading by and large. Although I did read that if the 6WB mileage is lower than your car's cluster, the new 6WB will adjust and take on the mileage from your car. i don't know how accurate that is, and I'm not sure I'm willing to experiment without some guidance.
      06-18-2021, 11:22 PM   #4
540iSUP
Drives: G30, E36
Bimmer-tech might be able to help.
https://www.bimmer-tech.net/category...nt-cluster-6wb
      06-19-2021, 05:35 PM   #5
beerman80
Drives: BMW M550i
Originally Posted by 540iSUP View Post
They want $2899 which is a little too much for me.
540iSUP704.00
      06-20-2021, 06:08 PM   #6
chuddism
Drives: 328xi
Same.
I'm not sure their pricing is 100% reasonable. You should have seen the quote for surround view. I understand it won't be cheap but be realistic!
540iSUP704.00
      06-22-2021, 06:02 AM   #7
540iSUP
Drives: G30, E36
Same.
I thought I was the only one who had issues with their pricing.
      06-24-2021, 08:16 AM   #8
CHECKERED
ex deus machina
CHECKERED's Avatar
Drives: G30, F15, Audi S4
don't go with bimmer tech, they are outrageous, you might as well go to the dealer
here is a company selling used virginized clusters,
https://bimmer.guru/product/bmw-digi...-5-series-g30/
cost + shipping for me was going to be ~$900
so I just went for a new one
https://www.ebay.com/itm/222376814261 for ~$1100 + $60 for trim
easy install, self coding with e-sys is a bit awkward but everything works perfect
Daily: G30 M550i, Bluestone, JB4, 1 step colder plugs, 6WB retrofit
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods
Wifes': F15 M50d clone, DUDMD tune, WMI, MPBK
Gone: E92 335i N54 468rwtq
      06-24-2021, 09:23 AM   #9
chuddism
Drives: 328xi
Literally just got mine done!
I bought a virginized cluster off eBay. came overnight from Europe.
Installed it this morning and just had it remote coded by Mrgicm.
Not a hard swap at all.
Now, the surround view swap im thinking about will probably suck haha.
540iSUP704.00
      07-10-2021, 09:18 PM   #10
krunchyfu
Drives: BMW G30 M550i Carbon Black
Do you mind me asking which seller you bought your cluster from? TIA!
      07-12-2021, 07:34 AM   #11
chuddism
Drives: 328xi
Sure.
It was this guy - https://www.ebay.com/str/antoniosatnav
No affiliation. worked great for me. YMMV.
super quick delivery to the US. (Literally like 2 days).
Good luck.
      07-14-2021, 08:50 PM   #12
krunchyfu
Sure.
Good luck.
Thanks so much. Is this the part that you ordered? https://www.ebay.com/itm/11483782959...AAAOSwFHFgWukK
      07-15-2021, 10:11 AM   #13
beerman80
Drives: BMW M550i
Sure.
Good luck.
Even though the description says "6WB" I don't think it's correct since it doesn't have the rings? I am curious though as I am also looking to purchase one of these.
      07-15-2021, 09:31 PM   #14
krunchyfu
Thanks so much. Is this the part that you ordered? https://www.ebay.com/itm/11483782959...AAAOSwFHFgWukK[/QUOTE]
Even though the description says "6WB" I don't think it's correct since it doesn't have the rings? I am curious though as I am also looking to purchase one of these.[/QUOTE]
Sure.
Good luck.
Doing a bit of reading, I agree and don't think this is suitable for pre LCI G30s
      07-16-2021, 10:47 AM   #15
chuddism
Drives: 328xi
Definitely not right. That's for the LCI ID7 cars. Not Pre-LCI.
      07-16-2021, 10:50 AM   #16
chuddism
Drives: 328xi
Not that one.
this is the one you want. with the metal rings.
https://www.ebay.com/itm/22237681426...0AAOSwnw9aBY9N
Just be careful if you don't buy new to make sure its Virginized. That's important because you want the previous car info cleared before you install.
Doing a bit of reading, I agree and don't think this is suitable for pre LCI G30s[/QUOTE]
      08-11-2021, 04:30 PM   #17
beema_geeza
Drives: G32 6GT
I already have 6WB but I’m going to retrofit the full digital blackout version.
My car has hud but the kombi I’m buying doesn’t.
On the back is a silver box that is identical to the blackout version. This is where hud plugs into. Does anyone know if I just swap the boxes, hud will function as before?
There are 2 versions to this kombi, this one with silver box is for evo which is why it’s got the blue plug that goes to the evo orange connector.
The id7 version is different on the back it has the black plug and a purple connector for hud. I don’t think it requires hsd cable to mgu
I think the only difference is the rings are missing on the full blackout version, I don’t think there’s any actual change to the kombi unit. So is it worth it?
It’s simple if you have the correct tools to virgin the eeprom so once I’ve done it I’ll put on here.
I’ve fitted a few kombi units in F20 F30 etc
      08-15-2021, 06:33 PM   #18
krunchyfu
Successful 6WB Retrofit
Hi Gang,
As an update, I've successfully retrofitted a used, virginized 6WB. I found one on eBay for ~$650 and pulled the trigger.
Some notes:
- You'll need a new cluster trim (part # 51459387222), however it is possible to remove the top 2 clips of the 6WA trim and cover with felt.
- Mrgicm was a total wizard and coded the new cluster for me, along with anti dazzle and default radar cruise to closest distance.
I'm so happy with the replacement - the car feels so much more modern and the new Eco Pro display is so cool!
      08-15-2021, 06:34 PM   #19
krunchyfu
You'll definitely need a version that has the plug for the HUD, else it won't work. I'm not sure this will be as big an upgrade as 6WA -> 6WB.
      02-10-2023, 02:53 PM   #20
ericgc1101
Drives: BMW G30 (530i)
Hi, I have a question and hope you can help. I'm about to purchase the used cluster off the website you provided but I was wondering what the install process would look like? Is it as simple as just unscrewing the cluster, or will I have to remove the trim where the ambient light is under the idrive screen as well?
      02-13-2023, 04:59 PM   #21
CHECKERED
ex deus machina
CHECKERED's Avatar
yes its that significant
trim around cluster as well as trim below the cluster on both sides (left of the steering wheel and the one under the idrive screen
the dense foam that dash is made from makes removing the trims a PITA, I broke three trim tools
      02-16-2023, 02:57 PM   #22
ericgc1101
Sounds good, thanks for the reply! I'll be receiving the new trim tomorrow so I hope it goes well
5post
