speakers under seat??
04-25-2006, 08:55 PM | #1 |
Rep 858
Drives: 2010 e90 328i Msport
i just noticed the speakers under the seats today...are they the subs for the car??? does anyone make upgrades for these???
AW 2010 E90 LCI |
04-25-2006, 09:01 PM | #2 |
Rep 57
LOL, they're 8 inch subs i believe, part of the logic 7 package. I wouldnt upgrade those as they are specifically designed for the unique enclosure they are housed in.
04-25-2006, 09:01 PM | #3 |
MAUI BUILT
488
Rep 7,781
Drives: 2006 330i MT
Yup, those are the subs. As for upgrades, I'm sure it's possible.
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
04-25-2006, 10:54 PM | #4 |
Rep 370
Drives: E90 325xi
not jsut for logic 7... it's standard on all US e90's. the subs are actually some weird 8.5 inch (not quite)... so it's difficult to replace. 8's would work if you made an adapter bracket/ring for it.
04-26-2006, 07:52 AM | #5 |
Rep 1,391
Drives: F10 G29
Can you see the sub under seat....or it is inside the seats?
I am not sure if mine has it? Anyone has a photo of the sub under the seat? |
04-26-2006, 07:58 AM | #6 | |
Rep 472
2006 330xi
BMW, please get rid of the RFT's and give us a spare tire! |
04-26-2006, 11:49 AM | #7 | |
Rep 370
Drives: E90 325xi
It's standard in the U.S. But in HK, you have to upgrade your sound system to get it, I believe. |
04-26-2006, 01:08 PM | #8 | |
Rep 1,391
Drives: F10 G29
04-26-2006, 01:20 PM | #9 |
Rep 17,767
Drives: F36 428i,E90 328i, E85 Z4 3.0i
RikuE90: I believe the standard system in the US on 325is is the Hi-Fi system (mid-grade BMW audio offering). It is a 10 speaker system (Front: 2 mid-range speakers, 2 tweeters, 2 subwoofers Rear: 2 mid-range and 2 tweeters). You should have this, peek under your front seats to locate your small subwoofers...
Logic 7 (Optional on the 325 and standard on the 330s) adds 2 more in the rear and a center speaker on the dash.
Official DC Metro Registry - Current, New & Prospective Area Members Roll Call! |
04-27-2006, 06:48 AM | #10 |
Rep 1,391
Drives: F10 G29
thanks guys for your help.....I have located the 2 speakers on the floor under the front seats......
finally I have located all of the ten speakers. |
04-27-2006, 02:03 PM | #11 | |
Rep 17
http://www.bmwfaq.com/showthread.php?t=119763 See you |
01-11-2014, 12:55 AM | #12 |
Rep 135
yes they are 2 8s. u can upgrade. but will need a 1/4 spacer, dremel, another amp.
check this out and i have 27 page pdf on how to do so
330i '04 sold
335xi '07 400hp sold 435xi '14 360hp sold M3 CP '17 444hp |
08-03-2014, 05:55 PM | #17 |
Rep 130
Drives: 2008 328i Sedan Sports
Another repost haha. But seriously. Why does everybody get so mad at ancient bumps?This is the first thing that pops up on google about this.
In my case my 328 I just bought I've realized the previous owner removed these under the seat which is a reason to be pissed. Obviously he did an upgrade and got rid of stocks and wanted to keep whatever he put down there. But a good opportunity for an upgrade for me. Just added a sub and amp but don't want to same for fronts. I am trying to figure out what I can drop in. Ohm/watt wise etc.
2008 E90 328i Sport Sedan
335 189 wheels/Eibach Pro-Kit/H&R 10&12mm/K&N/Charcoal delete/LED Past:2012 R56 MINI S/1992 E34 525i/1989 E30 325ic |
08-03-2014, 06:09 PM | #18 | |
Rep 5,120
08-03-2014, 06:32 PM | #19 |
Rep 1,192
Drives: 2011 335i MT
PTF Map, Pure Turbo Stage 1, GFB DV+, Mfactory LSD, AA FMIC, B12 Pro Kit, M3 FCA, AR DP and
Dynavin N6, Mosconi AS100.4, AS100.4, AS200.2, Micro Precision tweeters & woofers, Esotar2 1200 |
08-03-2014, 06:34 PM | #20 |
Rep 130
Thanks BMW 325i. I will use the newer thread.
