BMW M3 and M4 - The Icons
home
Technical Sections Coding, Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics
      07-01-2021, 12:13 PM   #1
kwilliams312
Drives: 2021 G80 M3
Pinout for Amplifier
I'm looking to add my own DSP to the car, since the major vendors are saying December/January at the earliest, does anyone have the electrical diagram, or know the pin out of the amplifier's output section?
I'll be using line-level inputs to a DSP, and then most likely running my own speaker cable to the speakers.
Thanks!
      07-02-2021, 12:04 AM   #2
moproblems
Beware of cheap bait!
moproblems's Avatar
711
Drives: 2021 M4 Isle of Man Green
Are you looking for line level out of the headunit to the amp? Is more than likely digital fiber optic.
      07-05-2021, 01:10 PM   #3
kwilliams312
Drives: 2021 G80 M3
It is likely optical from the head-unit to the amp, yes; the iDrive7 system isn't MOST, so it's not as easy as getting a MoBridge device. Currently the only option is line-level outputs from the AMP into a DSP with input AND output EQ control.
I have a ton of gear prepped to build a SQL competition system, I'm trying to find a reasonable way to integrate a DSP and set of amps without modifying any wiring harness.
      07-16-2021, 12:33 PM   #4
Encanto
Encanto's Avatar
Drives: 2021 X3 M40i
It is AES from OEM HU to RAM via Ethernet.
      07-19-2021, 01:58 PM   #5
kwilliams312
Drives: 2021 G80 M3
I understand that it's ethernet and encrypted, I'm looking for the analogue output wire mapping from the RAM to the speakers.
g80
