07-02-2021, 05:38 PM | #1 |
Rep 37
Front Bumper Air Grille Cover - front right PDC sensor
Hi All,
Can anyone please help (or point to the right source of info) on replacing of X3 G01 Front Bumper Air Grille Cover (right, part 51117459520) and Cover Insert Lower (right, part 51117422946, if its applicable) without removing the whole bumper? The purpose is to replace the PDC sensor on the right side without 'dismantling' the whole bumper assembly. Thank you! |
07-02-2021, 05:52 PM | #2 |
A family of bimmers
2757
Rep 7,743
On my m40i I was able to use a pry tool starting with the upper portion on the outside and work my way around to the center to remove. Not sure it's the same on the xline or not but I'd imagine it is based on the part diagram
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
07-02-2021, 06:54 PM | #3 | |
Rep 37
I saw the procedure: but it's different for Xdrive 30i I am looking for. |
