07-02-2021, 08:22 PM | #1 |
Rep 4
Rear air vent panel
Hello guys,
I hope someone can help me. Someone broke my rear air vent wheel. The dealer quoted me $600 to replace it. I found the rear vent panel on eBay for $80 and wanted to replace it my self. https://www.ebay.com/itm/2020-19-BMW...-127632-2357-0 Does anybody know how to get to this panel to replace it. |
07-02-2021, 09:48 PM | #2 | |
Rep 578
07-03-2021, 08:37 PM | #3 |
Rep 3,954
It has 8 retaining clips around the panel. 4 on each side. Slowly pry at the seam on each side till it releases from center console, remove wire connectors and reverse procedure for installation.
07-03-2021, 08:47 PM | #4 |
Self-Deprecating Narcissist
7274
Rep 6,561
Why isn't warranty covering this repair/replacement?
07-03-2021, 10:53 PM | #6 |
Rep 4
If you look at the pictures from eBay (the top view) it looks like there are 4 screws that are holding it. One at each corner.
07-04-2021, 04:44 AM | #7 |
Rep 109
I've had mine off a couple of times when I was fitting a wireless charging pad on the centre armrest. Its just held by clips. Start at the bottom and give a firm (but not aggressive) tug until the bottom clips pop, then work your way to the top. The electrical connectors are fiddly but once you work out where the little lug is that you have to depress on the plugs they come off quite easily.
2020 M50d - Arctic Gray with Ivory White/Black Vernasca
07-04-2021, 07:13 PM | #8 | |
Rep 3,954
