BMW M3 and M4 - The Icons
home
Technical Sections Suspension / Brakes / Chassis
      07-05-2021, 07:37 PM   #1
Telly9987
Just a guy with a heavy foot
Telly9987's Avatar
Drives: G80
KW DDC ECU WLAN Module
What does the KW DDC ECU WLAN Module do? Im assuming its a controller for KW electronic suspension kits. I cant seem to find info on there website about it.
Im assuming no, but is there any chance this box allows use to fine tune the stock electronic suspension in the car? Meaning create our own profiles?
      07-07-2021, 12:47 PM   #2
Salespunk
Drives: Slow
It is typically the error cancellation module for EDC equipped cars. When you put on the coilovers is removes the error light and makes sure that the rest of the connected systems function properly.
Telly9987180.00
      07-07-2021, 06:07 PM   #3
Telly9987
Telly9987's Avatar
Drives: G80
As I assumed... Thanks so much. Kinnda figured that after the same product from KW is available for just about every hypercar out there with EDC.
      07-08-2021, 12:28 AM   #4
Brickologic
Drives: 1MCoupe M5
NOPE.
THE DDC ECU WLAN (WiFi) Box is the wifi unit for the adaptive KW DDC controller. So you can adjust the damper curves of your ddc shock via smartphone, if you have a so called ddc ecu kit from KW.
https://www.kwsuspensions.com/produc...rs/ddc#ddc-ecu
http://blog-int.kwautomotive.net/the...ension-is-now/
      07-08-2021, 12:31 AM   #5
Salespunk
Drives: Slow
Originally Posted by Brickologic View Post
NOPE.
Wow sounds super trick!
g80
