BMW M3 and M4 - The Icons
home
Technical Sections Cosmetic and Lighting Modifications
      07-08-2021, 04:51 PM   #1
mzcp
Drives: BMW M
Retrofit F10 M5 Illuminated Shift Knob
I will be retrofiting the F10 M5 Illuminated Shift Knob to my G80. Does anyone have the wiring diagram for the Center Console? I need to tap two wires to the harness. I took out my shift knob with the pictures below exposing the harness.
      07-09-2021, 09:11 AM   #2
cwhands
Drives: F80 M3 SS/CSAT 6MT
The factory G8x shifter is not illuminated?
      07-09-2021, 09:26 AM   #3
mzcp
Drives: BMW M
No its not
      07-09-2021, 03:21 PM   #4
Griz
Drives: 2010 E92 M3
This has been a recurrent theme with BMW M3s. My '99 E36 had one, but it was only available 98-99 for that build. My '10 E92 did not have one.
Perhaps BMW is hoping we know how to find the shifter (and gears) without visual assist.
      07-09-2021, 03:47 PM   #5
mzcp
Drives: BMW M
Yes it weird the F8X M3/4 had it but not the F87
      07-09-2021, 06:55 PM   #6
cwhands
Although completely unnecessary, I do think it's a nice touch
      07-19-2021, 02:14 PM   #7
mzcp
Drives: BMW M
Bought the connector and the wires to retrofit
Nkr151124.50
      07-20-2021, 09:20 AM   #8
moproblems
Beware of cheap bait!
moproblems's Avatar
711
Drives: 2021 M4 Isle of Man Green
What wires are you hooking them up to?
      07-20-2021, 09:56 AM   #9
mzcp
Drives: BMW M
I am still waiting for the F10 knob to be transferred to the original boot. The shop needs to look at the harness. Thanks for the diagram
      07-20-2021, 01:17 PM   #10
nearwater4me
Drives: '22 G82 Base
Would you be able to post some more details once everything is hooked up?
Thanks!
      07-20-2021, 01:37 PM   #11
mzcp
Drives: BMW M
Thanks!
Sure I followed your DIY for my M2C knob.
      07-20-2021, 02:38 PM   #12
nearwater4me
Ah, that's right! I remember chatting with you.
Still haven't decided when I'll be making the jump but once I do, I'd definitely want the illuminated shift knob back.
Thanks a lot!
mzcp2692.00
      07-21-2021, 01:58 PM   #13
mzcp
Drives: BMW M
More pics
      07-21-2021, 03:46 PM   #14
krakenXIV
Portugal
77
Drives: G82 '21 / Mini SE '22
Would you consider making kits later on?
      07-21-2021, 04:21 PM   #15
mzcp
Drives: BMW M
You can buy the kit from Leatherz but its not cheap here
      07-21-2021, 04:47 PM   #16
heckyeahbro69
heckyeahbro69's Avatar
518
Drives: m3
bdc to console switch
mzcp2692.00
      07-21-2021, 05:20 PM   #17
mzcp
Drives: BMW M
Thank you sir. That will help a lot
      07-30-2021, 03:04 PM   #18
mzcp
Drives: BMW M
Thanks to Heyckyeahbro69 and Moproblems for the wiring diagram.
The shift knob light can’t be dimmed as in previous generation. It is powered off the Center Console Parking Assist Engine Stop switch module. I tapped into the Brown/Black and Green wires.
M3-san252.50
element561092.00
MT6729.50
      07-30-2021, 03:05 PM   #19
mattssi
Drives: 2019 X3
Looks cool! Too bad on the dimming
      07-30-2021, 03:11 PM   #20
mzcp
Drives: BMW M
Yeah too bad for the dimming.
      07-30-2021, 11:22 PM   #21
nearwater4me
Thanks for sharing the info!
I’m assuming the brown/black wire feeds to the brown/white wire on the LED knob (ground)?
As for the dimming, I wouldn’t mind it. It’s brighter!
      07-30-2021, 11:25 PM   #22
mzcp
Drives: BMW M
No problem. Let me double check on the ground wire later. I forgot to take a picture of that one lol
g80
