F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Help - Fuel leak on driver side!
Studio RSR
      07-16-2021, 01:23 AM   #1
1bad14-F30
1bad14-F30's Avatar
Drives: 2014 335i M Sport
FUEL LEAK
It only leaks if I fill it up. If I only fill it just past 3/4, it doesn't leak, but still smells strong. It leaks from the top of the tank and down. I removed the seat and took the plate off to see if it was the gasket for the LPFP, but it was dry. Could this be a Fuel Tank Vent line issue? Or something similar? Could it be the Fuel Pump? Like I said it was dry around the ring area, but I could feel fuel on the shelf on the tank below where the Fuel Pump mount is. For those who have had this issue or know of it, what, if anything, can I do to check this and or replace as necessary? If it is the Fuel Pump, and I have to get in there, I'm gonna upgrade to the Precision Raceworks Stage 2 pump.
2014 335i - BM3 Stage 2+ Race Gas, VRSF Catless DP, Race IC, CP, Muffler Delete, xHP Stage 3, NGK 97506, Eldor Coils, Turner Motorsport intake with BMS filter, BMS Oil Catch Can, Red Line fluids.
      07-16-2021, 05:07 PM   #2
1bad14-F30
1bad14-F30's Avatar
Nobody?
f30post
