07-29-2021, 05:17 AM | #1 |
5385
Rep 3,795
MSS HAS Kit and settling period
There have been some requests for further explanation of the time the MSS kit takes to settle so I'm posting this to explain with advice from MSS themselves.
MSS use well known German manufacturer Eibach for the springs used in their kits. These are made to MSS specifications. Eibach have a range springs called ERS - Eibach Race Springs. These are specifically made for Motorsport and the raw material is different to their standard Pro-kit or S-line springs. ERS can withstand the greater heat cycles to be expected in race conditions regardless of the discipline - F1; rally; endurance racing and the like. MSS chose this material over the standard Eibach Pro-Kit for quality and longevity which is reflected in the lifetime warranty provided by MSS. These springs will take longer to settle but then will not sag over time like springs made from other materials. MSS state the settling period is 2000 miles but this obviously depends on the type of driving and type of roads the car is driven on. It can be a lot less than this with spirited driving which will compress the suspension more than just cruising on the highway. Here are some pictures of Evolve's shop car and our friends Basic Performance shop car which were the first cars to be fitted with the MSS HAS kit. Also important to bear in mind that MSS engineer their kits primarily with ride comfort and handling in mind. They won't sacrifice these two attributes for maximum lowering on stock dampers. |
07-29-2021, 05:28 AM | #2 |
Rep 1,385
Thanks Imran,
Just fitted my kit yesterday and I'm very happy with it. The ride quality is just like the stock which is what I want with no noticeable change over the OEM set up. (my wife will never know that the car has new suspension ) This is a picture of the car straight off the lift with no miles. It already looks better than stock but look forward to getting some miles on it and settling in. Thanks for the update |
07-29-2021, 08:00 AM | #3 |
Rep 1,290
Still doesn't look good to me in any of those pictures, rear is more saggy than the front even after the so-called 2000 adjustment period. To each their own I suppose.
2024 BMW M4 Competition XDrive - Tanzanite Blue/Kyalami Orange - AST HAS - RaceChip
07-29-2021, 08:20 AM | #4 | |
Rep 10,193
At first I was thinking I just want the fender gaps even but am revisiting what I finally want (which I can adjust easily with MSS). I do want a little more settling up front for sure. This was my car stock: Now with the MSS and about 140 miles since the drop (I know I know- need to drive more):
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
07-29-2021, 08:25 AM | #5 | |
Rep 1,385
This 'rake' idea is purely for aesthetics. If you want the perfect 'stance' you're probably going to need coilovers and you're probably going to have over steer / worse handling than stock if the back end is lighter than the front |
07-29-2021, 10:40 AM | #6 |
Rep 10,711
Drives: M4 CS. Former G82, x2 F82, F80
Just not good enough, need full coils. I’m never going springs only again, learned my lesson with last two cars I tried them on.
07-29-2021, 02:27 PM | #7 |
Rep 1,290
On my M4 the front and rear are pretty even stock. I'd want to keep the same proportions with springs. Hopefully, the KW HAS I have coming will do the job.
I wonder why the M3's rear has more squat than the M4.
07-29-2021, 02:46 PM | #8 | |
Rep 10,193
I took this pic before I changed my mind and went with the G80 vs 82:
MarineRaider1193.00 r33_RGSport13042.00 |
07-29-2021, 05:58 PM | #9 |
Just a guy with a heavy foot
180
Rep 239
Had mine on for about 3 weeks now. Did some spirited canyon driving and a track day. Settled a tad but no where near what Im looking for.
KW released the full coil overs and they claim a bit more drop in front but for 6K$
...::•Purveyors of Speed•::... http://www.MotorsportExotica.com https://g80.bimmerpost.com/forums/showthread.php?t=1828818 |
07-29-2021, 09:48 PM | #10 |
Rep 2,068
I'm super happy with the kit.
I don't really want another slammed car. It's just too much of a hassle. |
07-29-2021, 09:54 PM | #11 |
Rep 2,167
Trent, that drop is perfect for me. I definitely still want some space between the tire and fender. Neither am I slammed guy, I just want a subtle drop...especially in the front. How's the ride compared to stock at your height?
TrentMeister2944.00 |
07-29-2021, 09:56 PM | #12 |
Rep 1,290
I feel like it looks better on the M4. Is that default drop settings or did you raise the rear?
07-29-2021, 10:52 PM | #13 | |
Rep 2,068
I'm super happy with it like I said and only the steepest of driveways have even come close to scraping. I've got 18mm spacers up front so it does in fact rub on ps4s while I'm backing up at about 80% lock. |
KevinGS3371.00 |
07-29-2021, 10:56 PM | #14 | |
Rep 2,068
I'd say I'm 12-1500 miles of good dynamic driving into them. I saw that mss finally released their statement on why they take so long to settle and their explanation basically points to quality of product so I'm a happy customer. |
07-29-2021, 11:52 PM | #15 | |
Eleet Tech
183
Rep 295
TrentMeister2944.00 Imran@Evolve5384.50 |
07-31-2021, 04:06 PM | #16 |
Rep 136
As these take time to settle, when should you perform an alignment?
MarineRaider1193.00 |
