11-08-2008, 12:39 PM | #1 |
Rep 1,068
How to connect these cables?
This is a shot in the dark, but hopefully some of you with electrical skills will be able to help me.
I have 4 of these cables (small, internal audio/power cables) that I want to connect end to end to make one long cable. What is the easiest way to do that? Are there male-male bare pins that will connect them or a male-male cable or do I have to solder them together? (I'd prefer not since I don't know how to do that). Thanks in advance! |
11-08-2008, 02:18 PM | #3 |
Rep 1,068
I'm trying to retrofit a steering wheel with paddles. So this wire will go from the slip ring in the steering column all the way down to the gear shift area where I will connect it to the steptronic system.
11-08-2008, 03:59 PM | #4 | |
Careful, I Bite.....
157
Rep 504
Then just cut the unneeded connectors off, splice the wires together, and electrical tape them together. |
11-08-2008, 04:01 PM | #5 |
Rep 4,201
Drives: F30 328i
I wouldnt use electrical tape for this application..Your better off using heat shrink!!
11-08-2008, 04:03 PM | #6 |
157
Rep 504
