M2 Technical Topics > Suspension | Brakes | Chassis > My stock damper leaking
      08-08-2021, 03:59 PM   #1
Rub1con76
Drives: Bmw F87 M2
Hi Guys
I got my M2 lowered with H&R HAS kit and got a new damper at the left rear after an small accident.
They only replaced the rear left side and now we are 7 months later and its leaking again.
Went back to the dealer and gonna get a new one again. But what bothers me is that they only replace one instead of the whole axle.
@Rub1con76
      08-09-2021, 12:55 AM   #2
n8dgr84
572whp Stock Turbos/DP E60 Tune by Tier1Tuning
182
Drives: M2C - 6MT - Flex Fuel
I'd be impressed if they replaced it under warranty.
What's your ride height set at?
      08-09-2021, 09:57 AM   #3
Rub1con76
Drives: Bmw F87 M2
Lowered but not at his max
@Rub1con76
      08-09-2021, 10:28 AM   #4
MR RIZK
MR RIZK's Avatar
Australia
758
Drives: AW M2C
Excerpt from the BMW M2C repair manual
33 00 ...Information on replacing shock absorbers
Situation:
When a shock absorber is faulty on one side (leaking, noises, limit values exceeded on the shock tester), often both shock absorbers on the axle in question are replaced.
Effect:
This is not necessary for technical reasons and causes the manufacturer not to recognize the unnecessarily removed shock absorbers as defective parts. Unnecessarily high costs for the customer can be avoided by replacing the shock absorber on one side only.
Procedure:
If one shock absorber is damaged, it is only necessary to replace both shock absorbers when the car has driven in excess of 80 000 km.
Exception: On all M‐GmbH models, when a limit value is exceeded on one side, it is still necessary always to replace both shock absorbers on the relevant axle.
Previous Rides: 13' 135i, 08' 130i, 03' HKS Turbo'd 350z, Modded GC8 WRX, NA MX5
n8dgr84182.00
      08-09-2021, 11:16 AM   #5
Rub1con76
Drives: Bmw F87 M2
Situation:
Effect:
Procedure:
Okay, i have 75k km at this moment.
So it's recommended to switch both left and right side?
@Rub1con76
      08-09-2021, 11:32 AM   #6
n8dgr84
182
Define "limit value"?
Is it related to mileage or some shock-specific wear limit?
      08-09-2021, 12:06 PM   #7
M Fifty
Drives: M2 & 330CI
The shock tester 'should' just be measuring the bump and rebound damping rather than extension and compression.
      08-09-2021, 02:28 PM   #8
nioh_lbbm2
nioh_lbbm2's Avatar
1717
Drives: M2
Time to take off the lowering springs since they kill shocks faster. Switch to coil overs.
You're lucky if the dealer is choosing to cover you under warranty with lowering springs.
      08-09-2021, 02:54 PM   #9
Rub1con76
Drives: Bmw F87 M2
Yes idd, i gonna buy my friends Mperformance coiloverset when he sells his M2.
I will update you tomorrow if its switched under warranty
@Rub1con76
      08-09-2021, 04:40 PM   #10
x233
Drives: M2C, M235xi
Agreed, it's just common sense to replace both, warranty or not, especially at this point in their lifetime.
Rub1con76202.50
      08-10-2021, 01:46 PM   #11
Rub1con76
Drives: Bmw F87 M2
They replaced the broken damper but not the other one .
@Rub1con76
m2
