08-12-2021, 07:41 AM | #1 |
Rep 9
Tapping Audio Outputs to Add a Subwoofer to Harmon Kardon
I am wanting to add a sub. Going with self amplified JL 12 400 watt. Question is I want a clean signal thus would like to avoid line level speaker outputs. First has anyone else added a sub? Second, What are you options for signal tap? In my old car I was able to tap the balanced line outputs and run it to jl balanced to unbalanced converter then run rcas to my amp. This is the Harmon Kardon on M3 G80 2021. Also any links to wire pin outs would be great.
08-12-2021, 07:59 AM | #2 | |
Rep 897
M4Tejas804.00 |
08-16-2021, 03:37 PM | #4 |
Rep 200
What would prevent you from simply tapping the wires connected to the under-seat subs? That's what I intend to do. Four bolts for the seat, four screws for the speaker cover.
11-15-2021, 12:11 PM | #5 | |
Rep 6,593
Jrdeleond0.00 |
11-15-2021, 12:40 PM | #6 |
You got my money?
3191
Rep 4,669
Drives: Ice Cream Truck
I have always used member Technic wiring harness with great success on my prior M cars. I would double check with him on what version to purchase. I think this is it, but I am not 100% sure. https://technicpnp.com/product/hk-op...oster-systems/
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
11-15-2021, 12:56 PM | #7 | |
Rep 6,593
BIGW0RM3190.50 |
11-16-2021, 10:40 PM | #8 |
Rep 35
Yeah i have a technicPNP harness with the LOC-150 so its plug and play no wire splicing. Running a JL 12tw3-d4 in a slim box for now. Going to get a custom corner box made soon, It sounds great. Make sure you code out the ASD or turn it off with the m-sound update cause it will play the exhaust sounds through you subwoofer amplifed (loudly).
11-26-2021, 12:27 AM | #9 | |
Rep 87
03-07-2022, 12:51 PM | #10 | |
Rep 1
Guessing you can really crank it up now as you are not relying on stock subs? |
03-14-2022, 04:31 PM | #11 |
You got my money?
3191
Rep 4,669
Bumping this. Has anyone added an external subwoofer yet? I am tempted to buy the technic harness and add a sub/amp I had in F80 M3.
03-14-2022, 09:10 PM | #13 |
You got my money?
3191
Rep 4,669
Awesome! Good luck with the install. Did you get the LOC-150 option too?
03-15-2022, 01:35 PM | #14 |
Rep 200
03-18-2022, 08:27 AM | #16 | ||
Rep 6,593
03-18-2022, 09:19 AM | #17 |
Rep 2,138
03-18-2022, 10:01 AM | #18 |
Rep 529
Could you describe a parts list for us on what you installed?
2022 G80 M3 AWD - Voodoo Blue
2020 G07 X7 M50i Tanzanite Blue II 2016 F80 M3 YMB *SOLD* |
03-18-2022, 12:14 PM | #20 |
Rep 2,138
Here are the items:
- Technic PNP Harness - LOC - Powered sub (RF P300-10) - Miscellaneous (Power cables, RCA cables, etc.) I threw in the RF P300 I had lying around. The sub fills in the bottom end that's missing. But even after some time trying to tune it, the system still doesn't sound balanced. I plan on getting a package setup once it becomes available. I'm also still waiting on BC to put the ASD decode function in the official release version because with the sub in the car, it sounds like a V8 with the low rumble lol. |
04-11-2022, 02:48 PM | #21 | |
You got my money?
3191
Rep 4,669
Question. Im about to buy the harness. But I am confused about a few of the plugs. I know the big plugs intercept between the amp. But what are the other three small plugs for? I assume one of them goes out to the LOC? If so, what are the other two plugs for? https://technicpnp.com/wp-content/up...ed-600x400.jpg
04-11-2022, 02:54 PM | #22 |
You got my money?
3191
Rep 4,669
^^^Disregard.
Technic just told me its a pigtail for amp'ing your stock subs and the other for your own LOC if you go that route.
Tags |
harmon kardon pin out, subwoofer |
