08-13-2021, 11:55 AM | #1 |
Rep 37
Lane change assist not working
I just swapped in my X7 for an IX3 and noticed that the lane change assist function is not working. Has anyone else experienced this?
08-13-2021, 04:33 PM | #2 |
Rep 30
It is not on the iDrive 7 systems as far as I know. My 520D 2017 iDrive 6 had it. The iX3 doesn’t come with it. That’s for sure.
But to be honest did you used it often? I experienced it as clunky. |
08-13-2021, 05:11 PM | #3 |
Rep 129
Hi is this what you mean? I think it has lane change assist
https://www.google.com/search?q=ix3+...J9u8PwKazwAI50 |
08-14-2021, 01:18 AM | #5 |
Rep 63
My iX3 has lane change assist and it actually works quite well. Even the assisted driving mode (simple self drive) works quite good.
It does depend on the version and you might need to ask your dealer. PS: lane change is part of the assisted driving mode and is configure able in the menu of the car |
08-14-2021, 01:23 AM | #6 | |
Rep 30
Well doing some more investigation it apparently is removed from the options list in the Netherlands and Belgium as far as I can see. Should we have to code it to activate this option, or did they had chip problems and removed this option at all? Last edited by DjCoke; 08-14-2021 at 01:44 AM.. Reason: On further investigation |
08-14-2021, 02:57 AM | #7 |
Rep 36
I fear that is one of those things that are dependent on national rules and regulations. Pretty sure it has also been disabled in Denmark.
Did a VIN-decode of my car and found the “S8TR - Decoding additional functions” Unfortunately much of the sales material on BMW national Danish website just appears to translated from the German site, as there a few features, e.g. Remote 3D view, that have been disabled, even though it is mentioned throughout the the website. It took a call to Connected Drive Support to find out, that this not legal in DK. Would be nice with a list of which features are enabled/disabled in different countries. Instead of having to spend time in the menus of the car, trying to find the different options. |
lakmus23.50 |
08-14-2021, 04:47 AM | #8 |
Rep 182
Drives: BMW iX3 G01
This is the same in Sweden sadly. The majority of automatic driving options in the IX3 menu is disabled due to country restrictions.
But it seems to be a coding solution for this on the G01 where you can switch country code and unlock the features. Not sure it works the same way on G08. Read more here: Lane Change Assist Coding - Working in the US https://x3.xbimmers.com/forums/showthread.php?t=1699204
09-11-2021, 06:26 PM | #9 |
Rep 601
The one I test drive in the UK had it, worked pretty well. I still dislike how Europe blocks cars being able to self steer over a certain %age, bet tesla driver in Europe hate that too, as full self drive will never work until its changed.
09-11-2021, 08:05 PM | #10 |
Rep 37
Finally, after going through two dealerships that didn't have a clue, BMW (UK) has confirmed it should be available. Should have lane change settings too but that's not in mine. Now to a third garage to see if they can sort it out.
11-02-2021, 12:10 PM | #11 |
Rep 852
Did you manage to get this activated?
11-02-2021, 12:37 PM | #12 |
Rep 601
Both demo cars I drove had it, I know some territories block it though, and know that the g01's had mods to enable the American version so it can steer over the euro specs %age.
I'll have a look when mine arrives hopefully in the next week or so! |
11-02-2021, 01:53 PM | #13 |
Rep 852
11-02-2021, 02:48 PM | #14 |
Rep 601
Like I say, worked perfectly in both demo cars I had, and they were UK spec. One with the blue bits the second without.
11-03-2021, 10:20 AM | #16 |
Rep 17
Lane change assist does not work on my UK car, if you indicate with assisted driving on the car gives up steering control until you get in to the next lane and then it resumes steering.
On the screen/hud the steering wheel changes from green to grey as soon as you indicate. If yours is truly working, what are the exact steps you are taking to make it change lane on its own? Are you tap indicating, full press etc?
Current Car: iX3 Premier Pro - Sophisto Grey Past Cars: X3 M40i, 330d MSport, 125d MSport |
11-03-2021, 10:52 AM | #17 |
Rep 81
OK so I have pretty much all the assistance options switched on. Let's say I am on the motorway I activate both lane assist and speed assist so the car is now steering itself in the left lane at 70mph and if the icons on the dash are green I don't have to do anything.
If i approach a car in front I indicate (full press) and the car moves out on it's own. i usually turn off the indicator when the lane marker is under the car. It then finds the new lane and carries on. Same to go back to the left, indicate fully and it moves back I'll have a look at the settings to see if there is anything there |
11-03-2021, 10:58 AM | #18 | |
Rep 17
On https://www.mdecoder.com/ do you have S8TR - Decoding Additional Functions ?
11-03-2021, 11:08 AM | #19 | |
Rep 601
My decode comes back..... Editions And Packages S7EZ Impressive S7M9 Individual Option High-Gloss Shadow-Line Comfort And Interior Equipment S413 Luggage Compartment Net S420 Sun Protection Glazing S423 Floor Mats Velours S430 Interior/Outside Mirror With Auto Dip S431 Interior Mirror With Automatic-Dip S481 Sports Seat S488 Lumbar Support, Driver And Passenger S494 Seat Heating Driver/Passenger S4K9 Inter.Trim Finishers Aluminum Fine Cut S4T2 LADEKABEL PROFESSIONAL (MODE 3) S4U0 Electroplat.Cover/Clip F.Operat.Elements S4U9 Acoustic Pedestrian Protection S4UR Ambient Interior Light S4V1 BMW ICONICSOUNDS ELECTRIC Multimedia S610 Head-Up Display S654 DAB Tuner S688 Harman/Kardon Surround Sound System S6AE Teleservices S6AF Statutory Emergency Call S6AK Connected Drive Services S6C4 Connected Package Professional S6DR BMW Drive Recorder S6NW Telephony With Wireless Charging S6U3 BMW Live Operating Area Professional S6U8 BMW Gesture Control S6WD WLAN Hotspot Driver Assistance And Lightning S534 Automatic Air Conditioning S552 Adaptive LED Headlight S5AC High-Beam Assistant S5AL Active Protection S5AU Driving Assistant Professional S5DA Passenger Airbag Deactivation S5DN Parking Assistance System Plus Wheels And Drive S223 Adaptive Suspension S230 Extra Package, EU-Speciifc S2PA Locking Wheel Bolt S2VB Tyre Pressure Display S2VC Tyre Repair Set Environment And Safety S302 Alarm System S322 Comfort Access S3DE Omission Of Specific Design Scopes S3KA Acoustic Comfort Glazing S3MC Indiv.Roofrailing,Mirror-Fin.Shadow Line S812 National Version England / Ireland S853 Language Version, English S880 On-Board Literature, English S8R9 Refrigerant R1234yf S8S2 Coding, Alarm Signal S8S3 Automatic Locking During Starting S8SM Car Ident. Number Visible From Outside S8TF Active Pedestrian Protection S8TG Thiefproofing Device S8TR Decoding Additional Functions Individual Equipment S760 High Gloss Shadow Line S775 Headlining Anthracite Other Equipment S1V7 BMW Lt-Alloy Wheel Aerodynamic 843 JB/GG S925 Dummy-SALAPA SA050 50 Ah AGM Battery
11-03-2021, 03:16 PM | #20 | |
Rep 81
S9QX Preparation Driver Assistance Which the other poster didn't have 🤔 But it also says my car is Left hand drive so I'm not sure it's wholly reliable 😂 |
11-03-2021, 04:17 PM | #22 |
Rep 17
Yeah mine does not have S9QX.
Mine says LHD too, def not accurate
