Intercooler sprayer
08-21-2021, 07:59 AM | #1 |
Rep 167
Intercooler sprayer
Has anyone installed an FMIC sprayer on their N54? I dyno’d 40whp more on my second run due to my FMIC being sprayed with a water bottle throughout the run. No tuning or fuel changes.
RB2s-MHD-FBO-INLETS-C/Os-SWAYS-BBK
08-21-2021, 09:17 AM | #2 |
Rep 3,732
I've seen where guys have had nitrous spray bars hooked up to their FMIC's......it will basically freeze the FMIC.
Honestly, unless you are drag racing and need that extra little boost to win a race......it's a lot more trouble than it's worth. Just have a runner dial in a couple pounds more boost...and there's your 40hp 😁 |
08-21-2021, 10:20 AM | #4 |
Rep 385
If you want to do this, just grab something from an old WRX or what not, modify it for your use and you're good to go. I've seen someone mess with the headlight washer valves repurposed.
Generally speaking a water/meth system is less hassle, easier to implement and adds some much loved octane on the N54.
2007 E90, 6MT, VRSF 7" FMIC, RR DP's, Vargas Stage 2+ (19t unclipped), CP-e Charge Pipe/Tial BOV, BMS DCI, Fuel-it! Stg 2 LPFP, E66, 118k+ miles Brentuned
08-21-2021, 10:36 AM | #5 | |
Rep 167
08-21-2021, 11:41 AM | #6 | |
Rep 940
what was the IAT on the runs ?
2007 E92 335i / FBO + Inlets / E85 Custom Tune by WedgePerformance / 9.68 @ 140 / TPC Stage 2 19T / 2.1s 0-60 mph / 2010 535Xi 6MT - 437M - MHD / Instagram @Silent9n54
08-21-2021, 02:00 PM | #9 |
Rep 940
are you on stock intercooler ?
that would be the only logical explanation how you made 40whp more if that small fmic was heat soaked
08-22-2021, 12:00 PM | #12 |
Rep 3,732
08-22-2021, 05:20 PM | #13 |
Rep 940
i dont think you would gain 40hp spraying nitrous there let alone water
08-22-2021, 05:41 PM | #14 |
Rep 167
Don’t forget that we didn’t get inlets until almost 2014. By then the engine wasn’t even in production anymore. People in the Subaru world include inlets in their FBO list. I was hoping FMIC spraying might be one that we forgot.
08-22-2021, 09:38 PM | #15 |
Rep 940
i have been spraying it on occasions when its really hot and i go to the track. Little to no difference, it goes down by a couple degrees. I have also tried spraying a 40lb bottle of Co2 which didnt help much either. You would need to spray nitrous or meth to have a noticeable effect. Also last n54 production date is 2016. Z4 had it.
08-22-2021, 11:03 PM | #16 | |
Rep 167
08-23-2021, 06:19 PM | #17 | |
Rep 167
08-23-2021, 06:36 PM | #18 |
Rep 940
i have a 2010 535xi and i know they have better lpfps, some people run e50 blends without issues. I think its on par with walbro 450s. I wouldnt be surprised if Z4s have a better pump too. I do know that they dont have a lpfp sensor so you cant monitor the psi which sucks.
08-30-2021, 04:26 AM | #19 | |
Rep 315
Robs rating on the RB Twos (and all of his turbos for that matter) are very conservative. Idk what he recommends for max boost on the standard Twos, but I'm sure they can eclipse 525whp while remaining well within their efficiency range for longevity reasons. A proper setup is a must, of course. Unfortunately, I don't think there's a cheap method to make that much more power without more stress on the turbos. Your best bet would probably be heavy E85 mixes on port injection. You might not be ready for that kind of investment, but I would at least keep it in the cards for the future. On 100% E85 and with the addition of outlets I wouldn't be surprised if the Twos could pretty safely make 550+whp with a quality tune.
07 335i
Mods: JB4 + MHD BEF, RB Twos Plus, Phoenix PI Manifold, Dual Walbro 450 LPFP's, DCI, VRSF DP's, VRSF 7.5" FMIC, VRSF CP + TiAL BOV, VRSF inlets & aluminum outlets, TC Kline SA, M3 F/R control arms, M3 subframe bushings |
08-31-2021, 01:46 PM | #21 |
Rep 3,732
08-31-2021, 02:10 PM | #22 |
Rep 167
