Cold Compression Test and Leakdown Test Results
08-22-2021, 08:03 PM | #1 |
Rep 513
Folks,
I recently did a cold compression and leak down test on my N54. The results are below: Compression 1: 150psi 2: 100psi 3: 100psi 4: 115psi 5: 115psi 6: 145psi Leak down: 1: 90psi at 90psi, audible leak 2: 85psi at 90psi, audible leak 3: 85psi at 90psi, audible leak 4: 90psi at 90psi, audible leak 5: 90psi at 90psi, audible leak 6: 90psi at 90psi, audible leak I suspect that the compression tests were so unusual because the engine was cold. The results of the leak down test seem to further suggest this. At this point, I'm nearly ready to fix/service the car for another ~2 years of use, but I wanted to verify my suspicions before going forward. Are my conclusions correct? Thanks, Last edited by Jonjt; 08-22-2021 at 10:21 PM.. |
08-22-2021, 09:34 PM | #2 |
Rep 1,165
Drives: 09 E92 335i 6MT
Those seem fairly low to me
I believe our's should be 150-200 on all cylinders I recently did a cold test, 131k miles cylinders 1-3: 179psi cylinder 4-6: 180psi I'd see if you could try a different tester? or retest, equipment may have been leaking
09 E92 335i 6MT / Alpine White / Coral Red / VRSF 7.5" / VRSF DCI / VRSF Catless Downpipes / VTT Charge Pipe / Turbosmart RacePort Gen V / RB OEM Billet Turbos / CD919 Custom Tune / Bilstein PSS9s
08-22-2021, 10:22 PM | #3 | |
Rep 513
I have 135k miles, by the way. |
08-22-2021, 11:22 PM | #4 |
Rep 1,165
I have a compression tester from Innova, part number 3612. Should be able to find it at most local auto parts stores.
08-23-2021, 07:55 AM | #5 | |
Rep 513
The engine makes good power, so I think a warm test would show more reasonable compression numbers. |
Dave92N54530.00 |
09-01-2021, 03:39 PM | #7 | |
Rep 1,893
Although I'd start with a higher pressure (at least 100psi), your leak-down shows an incipient problem with cyl 2 and 3, perhaps not coincidentally the cylinders which fared worst on the compression test. Typically, a new engine should have a leakdown of not more than 3-5% (95-97psi registered on 100 psi input). At 10-15% a rebuild should be planned. You're at 6% on cyl 2 and 3; probably fine for now. |
10-02-2021, 06:32 PM | #8 | |
Rep 513
10-06-2021, 07:58 PM | #9 |
Rep 42
No point in doing it cold. Warm it up and check it from there. As long as the numbers are consistent throughout the cylinders, send it. Those leakdown test numbers are fine.
Tags |
compression, leak, test |
