08-24-2021, 01:25 PM | #1 |
Rep 8,181
G8x M3/4 Alloy Wheel Weights List
824M
9.5x18 ET20: 9.8 kg / 21.6 lbs 10.5x19 ET20: 11.1 kg / 24.5 lbs825M 9.5x19 ET20: 11.0 kg / 24.3 lbs 10.5x20 ET20: 12.3 kg / 27.1 lbs826M 9.5x19 ET20: 10.8 kg / 23.8 lbs 10.5x20 ET20: 11.5 kg / 25.4 lbs829M 9.0x19 ET20: 15.0 kg / 33.1 lbs 9.5x19 ET20: 15.0 kg / 33.1 lbs963M M Performance 9.5x19 ET20: 9.5 kg / 20.9 lbs (9.9 kg / 21.8 lbs) 10.5x20 ET20: 10.5 kg / 23.1 lbs (10.9 kg / 24.0 lbs)1000M M Performance 9.5x20 ET20: 10.5 kg / 23.1 lbs (12.1 kg / 26.7 lbs) 10.5x21 ET20: 11.5 kg / 25.4 lbs (12.7 kg / 27.9 lbs)__________________________________________ Part numbers for M Performance wheels 963M frozen gunmental F 36108746989 R 361087469901000M black matt F 36109502044 R 361095020451000M goldbronze matt F 36108746991 R 36108746992__________________________________________ Part numbers for 829M winter wheels 829M black matt F 36108093844 R 36108093845829M is the recommended winter wheel set and is cast alloy, thus much heavier.
Last edited by swagon; 08-24-2021 at 05:32 PM.. Reason: Edited post to add weight figures for 963M and 1000M from BMW and Tischer, respectively |
15
Meanie546.50 Ilyam5897.50 forza19763399.00 JTO245276.00 mzcp2692.00 beachBmmr1450.50 PokGuy289.00 DoubleDave1176.50 MrBeranek26.50 DimM3302.00 NightWriter4844.00 VIERsr2623.00 M4Tejas804.00 backslashv106.00 Max Well4790.00 |
08-26-2022, 12:36 PM | #2 |
Rep 3,998
Here's info on the M4 CSL (827M) wheels for those interested.
9.5x19 ET20: 23.8 lbs 10.5x20 ET20: 24.2 lbs https://g80.bimmerpost.com/forums/sh....php?t=1937626
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic - for sale |
08-26-2022, 04:15 PM | #3 | |
Rep 8,181
Pretty impressive weight figure for a 20" BMW wheel.
Draper3467.00 |
02-09-2024, 10:28 AM | #4 |
Rep 1,184
0.4 lbs weight difference between F and R seems odd to me
all other have at least 2lbs difference I think the 24.2lbs for rear is wrong 1000M in 21 are not so bad... tempted to go 295/25/21 square F R for 20/20 there are the 863M from M5 just need a 10-15mm spacer to get the right ofsett |
03-04-2024, 02:22 PM | #5 | |
Rep 3,998
Others report similar numbers. https://g80.bimmerpost.com/forums/sh...4&postcount=52 https://g87.bimmerpost.com/forums/sh...1&postcount=11
03-04-2024, 03:32 PM | #6 |
Rep 5,783
WOW!! The weight of the 829M winter wheels is absurd - 33.1 lbm/wheel
The front and rear are narrower by 0.5” and 1.0”, respectively, yet they’re still way heavier. Ride quality is going to suck with those wheels and they probably bend easily. Inexpensive aftermarket wheels are a much better option for winter time. |
03-05-2024, 11:35 AM | #7 | |
Rep 8,181
F8x winter wheels are also cast, made by Ronal.
03-05-2024, 11:51 AM | #8 |
Rep 5,783
10-13 lbm increase in unsprung mass is significant. I can feel a change in ride quality on my f82 with 1/2 of that mass added. Also, driving f87s with and without the 2NH brake package have very difficult ride quality characteristics on bumpy roads.
03-05-2024, 04:29 PM | #9 |
Rep 8,181
I'm swapping wheels this weekend so will pay extra attention!
Tags |
g80 wheels |
