Sorry for the duplicate post - 335i purchase post serpentine belt failure
08-28-2021, 10:31 AM | #1 |
Rep 25
I couldn’t figure out how to cross post sorry for the duplicate post.
Hi, I’ve got a question for you all. I’m buying a car that within the last 4 months had a serpentine belt failure. It was taken to the dealership for it. They removed the carnage, did a “Crankcase smoke test” to make sure strands did get pulled through the front main. It says “OK” in the service right up. My question is, is that enough of a test and did the car get away with murder here? Would there be quick indications had they actually made it into the engine or is this more of a slow killer? The car has been driven since. I had the car PPId and they came back with the usual oil leaks and typical waist gate rattle but nothing majorly concerning. Cars been driven about 1500 miles since it shredded. I have to road trip the car a decent distance to get it home. I’ve already ordered spark plugs and coils. Do I need to replace pulleys to get it home? I’m just trying to get it back to do the remaining maintenance. What are your thoughts? Thanks! |
08-28-2021, 01:01 PM | #2 | |
Rep 3,219
When doing the belts, pulleys should be done too. Crank seals should be checked too in my opinion. Mine were ingested, engine survived though, mechanic managed to get pretty much all it out and did an oil change. Oil Filter Housing Gasket was leaking, so probably what caused the belt to slip and get ingested, previous owners didn't pay much attention to maintenence and I had leaks through every possible gasket, Valve Cover gasket, OFHG Sump gasket, crank seals, water pump, you name it lol. Since sorting them, car has been fine. |
08-28-2021, 02:19 PM | #3 | |
Rep 25
The cause of the break was a loose PS pump according to the service write up. First break happened on startup. He stopped immediately and had it towed. Second break happen about a month later and he cleared out as much belt as possible and checked around the crank pulley. He drove a half mile home and had it towed back to BMW. He says no leaks on the front main seal and nothing obvious in a recent oil change. |
08-29-2021, 02:21 PM | #4 |
Rep 20
I would drop the oil pan and check for pieces of the belt, in the pan and in the oil pick up tube. I personally have seen this cause a complete engine failure, after getting "repaired". The owner of the vehicle shredded the belt. The shop they brought it to, slapped on a new belt and sent them on their way. A couple months later complete engine failure, due to no oil pressure. The shop pulled the engine put in a replacement engine. And then opened up the failed engine. There were pieces of the belt almost everywhere in the engine, most pieces were in the oil pan and pick up tube. The car did not leak any oil thru the front seal, it seemed like it was fine. Sometimes the belt gets sucked thru the front seal and doesn't cause any noticeable damage to the seal.
08-30-2021, 03:05 PM | #5 | ||
Rep 6,968
Drives: 2007 Black/Black 335i e90
08-30-2021, 11:12 PM | #6 |
Rep 20
After what i saw, if i have a n54 or n55 that shreds the belt. I would not hesitate to drop the pan and make sure all pieces of the belt are removed. The front seal did not leak or show any signs of damage, yet the oil pick tube was jammed full of belt shreds.
I'm pretty sure dropping the subframe to check the oil pan is cheaper than a engine replacement. The oil pan gasket is prob leaking anyways. |
09-15-2021, 09:32 PM | #7 |
Rep 25
Just a quick update - car is beautiful. All of the usual leaks. Got it home and immediately changed the valve cover and oil/filter - among a bunch of other things. I have seen absolutely zero indication of ingestion. I plan to replace the oil pan gasket - already have it. Thank you all.
