09-03-2021, 03:41 PM | #1 |
BimmerPost Supporting Vendor
24358
Rep 191,163
Burger Tuning (BMS) G8x S58 intakes Regular & Front Mount **NEW PRODUCTS**
Install video
BMS Elite 2021+ G80 M3 G82 G83 M4 S58 BMW Performance Intake Gain up to 17+whp along with terrific sound. Finally, an intake system worthy of your S58 G80 M3, and G82 G83 M4! The BMS Elite G8x S58 Performance Intake retains everything that's good about the OEM intake including the cold air ducting and lightweight heat shielding airbox bottom but replaces the top end of the intake with higher flow 3.5" ducting and quality BMS inverted cone air filters to match. In addition to freeing up power, turbo spool speed was improved and there's an incredible sound improvement. You'll finally be able to hear your turbos spooling! Installation is easy and fully reversible. Our proprietary high flow filters can be cleaned every 15-20k miles using a cleaning kit and will last the life of the car. Our intake temperature testing found no significant difference from the factory intake during both sustained cruise and full-throttle operation. FEATURES AND BENEFITS • Adds up to 17+ Horsepower • Dramatic sound improvement • Super fast install and removal • Improves throttle response • Huge 3.5" mandrel-bent aluminum tubing • Classy gloss black powder coat finish • CNC Billet aluminum fittings • Retains OEM airbox base as a heat shield • Retains OEM cold air ducting • Looks great under the hood • Cleanable and reusable performance air filters • Made in the USA APPLICATIONS BMW M3 • 2021+ G80 M3 and G80 M3 Competition BMW M4 • 2021+ G82 M4, G82 M3 Competition, and G83 M4 Convertible BMS Front Mount BMS Elite 2021+ G80 M3 G82 G83 M4 S58 Performance Intake Gain up to 17+whp along with terrific sound. Finally, an intake system worthy of your S58 G80 M3, and G82 G83 M4! The Front Mount (behind the grille) BMS Elite G8x S58 Performance Intake completely removes the restrictive OEM intake and replaces it with 3.5" high flow ducting and BMS inverted cone performance air filters. The filters are placed behind the front grilles for maximum cold air induction. In addition to freeing up power, turbo spool speed was improved and there's an incredible sound improvement. You'll finally be able to hear your turbos spooling! Installation is easy and fully reversible. Our proprietary high flow filters can be cleaned every 15-20k miles using a cleaning kit and will last the life of the car. Our intake temperature testing found no significant difference from the factory intake during both sustained cruise and full-throttle operation. FEATURES AND BENEFITS • Adds up to 17+ Horsepower • Dramatic sound improvement • Super fast install and removal • Improves throttle response • Huge 3.5" mandrel-bent aluminum tubing • Classy gloss black powder coat finish • CNC Billet aluminum fittings • Looks great under the hood • Cleanable and reusable performance air filters • Made in the USA APPLICATIONS BMW M3 • 2021+ G80 M3 and G80 M3 Competition BMW M4 • 2021+ G82 M4, G82 M3 Competition, and G83 M4 Convertible Dyno Sound Clip
https://x-ph.com/sale/ Phone number 702-494-9435 Last edited by mike@x-ph.com; 10-13-2021 at 05:16 PM.. |
09-03-2021, 03:48 PM | #2 |
Rep 478
Did they provide any data with these? I had BMS intakes on my f80 and the car actually lost 3 hp, and the cold start was rough after install. I took them off and cold start went back to normal. A lot of F80 guys had similar feedback.
If they dont have any negative effects, I'd probably buy them for the sound alone. |
MocoLoco53.50 |
09-03-2021, 06:38 PM | #3 | |
Rep 911
Drives: 2022 G80 Comp x-drive
I have their intake on my G20, and could care less if I gained or lost 5HP. The sound of the turbos is worth every penny! Plus, they are made and designed great. |
MocoLoco53.50 |
09-03-2021, 07:07 PM | #4 |
Rep 7,007
Drives: 2022 DG/BLk xDrive M4C Wk 34
17HP from some filters? Is there supposed to be a decimal place in there, somewhere? Like 1.7? Id be worried about them getting wet, in that location.
2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou |
09-03-2021, 07:42 PM | #5 |
Rep 25
Gotta love the +17 horsepower….
Better throttle response? Come on… you're telling me when you're in sport+, that you can tell the difference between a stock Airbox and these silicone tubes? |
09-03-2021, 07:44 PM | #6 | ||||
Rep 25
09-03-2021, 07:46 PM | #7 |
Rep 6,593
09-03-2021, 08:13 PM | #8 |
24358
Rep 191,163
Dyno for the doubters
09-03-2021, 08:32 PM | #9 |
Rep 32
Drives: 2021 M3C BSM | 2018 M240ix (so
Since I live in Oregon and have lots of water exposure, I just purchased the regular mounted intakes. Excited to have them installed next week 😀
09-03-2021, 08:50 PM | #10 |
Rep 477
Looks great. Have used bms in past. Always a great product. The typical hate will be said and talk about heat soak. Let's be real when we are flying down the highway IATs are going to be lower other than at a dead stop but will probably just be even. Are these in stock !?
M4LAKA114.00 |
09-03-2021, 08:54 PM | #11 | |
Rep 32
09-03-2021, 09:10 PM | #12 | |
24358
Rep 191,163
bmw noob1458.50 |
09-03-2021, 09:43 PM | #13 |
Rep 559
I'm very interested… do you sell any filter socks? Not that I drive my car in the rain on purpose, but it happens.
I'm sure the sound is amazing, but I'm not sure about the potential water hazard…
This is my signature...
09-03-2021, 11:09 PM | #14 | |
Rep 911
That said, yes, that is expensive. But I would buy the “short-ram” version (essentially two of what I have in the g20), because every single time I hit the gas I smile from the turbo spool sound. It is worth every penny to me. If you don’t think it’s worth it, don’t buy it. And by the way, they are not silicone…they are very well made sturdy aluminum parts that use stock connection and installation place,ents. No need to bash a well made product. As to the fear of the CAI style, I don’t have any data on the true risk, but doubt it is anywhere close to as risky as you seem to think.
2022 G80 comp X-drive:San Marino Blue/ Silverstone, 826 bicolor, cf roof; exec pkg; shadow lasers; carbon pack; MSS HAS; spacers (15/12); Burger intakes; Unit17 front lip/CS Style spoiler; TLG flappies; full xpel ppf + 15% tint; AWE switchpath exhaust w/mid-pipes; csl strut brace; Eventuri cf engine cover
Gone: 2020 M340i; 2017 F30 340i; 2008 e92 335 |
09-05-2021, 12:35 PM | #17 |
24358
Rep 191,163
only 1 type of filters
BMWTurbo31.00 |
09-05-2021, 12:44 PM | #18 |
Rep 237
09-05-2021, 12:56 PM | #19 |
Rep 402
Any further input on the topic of water breach on the CAI vs. Ram?
Heading into fall I'd much prefer CAI vs Ram approach, but I do daily my car - it sees rain. Mike, do you have any thoughts on potential hazard, or any ways to go about safely? What about something like seen attached? |
09-05-2021, 08:30 PM | #20 | |
Rep 559
mattburks750.50 |
09-06-2021, 12:59 AM | #21 | |
Rep 1,093
mattburks750.50 |
09-06-2021, 06:34 AM | #22 | |
Rep 402
I, like our guy above, am chasing this 90% for audible, and 10% for aesthetics as I think the piping and cones looks cool as well. That shot with the blue cones I think will look sinister paired with the blue of the laser lights. |
Medal484.50 |
