09-06-2021, 07:27 PM | #1 |
BimmerPost Supporting Vendor
24358
Rep 191,163
Racechip GTS S58 M4 Comp Install Video + Before/After Dyno
Please note: The dyno used was a Mustang Dyno with a baseline of 427whp. for a fair comparison with a dyno jet (which reads 500 whp as a baseline for S58), we are comparing the delta in percentage and not absolute value.
the Racechip GTS made +13% WHP & +17% WTQ on 91 Octane (map 7) Here is the dyno w/ map 5 (default map) Full install video
09-06-2021, 08:37 PM | #2 |
Rep 494
Do some dragy pulls
09-07-2021, 08:30 AM | #3 |
24358
Rep 191,163
I'll try to get draggy pulls if i have time, cant make any promises as we have lots of installs and dynos scheduled
PLife647.50 |
09-07-2021, 09:51 AM | #5 |
Rep 494
Its throttle closures when you hit the torque limiter to keep the boost dialed constant. You dont feel it in the car and unless you tune the car to increase the torque safety limits all piggy backs will behave the same. Fyi this also happens in comfort mode
09-07-2021, 10:00 AM | #6 |
Rep 924
I have been driving in map 7 for almost a month. I have not experienced any throttle closures with lots of WOT driving.
2023 F90 M5
Retired - 2021 G82, 2019 440xi, 2020 X7, 2019 X5, 2013 F10, 2010 F10 |
TrentMeister2945.50 |
09-07-2021, 10:54 AM | #7 |
Rep 263
Would it make sense to install a cable extension for the hard-to-reach sensor so that if you do need to uninstall the Racechip for service visits it makes it easier to unplug and plug in the factory connector?
09-07-2021, 10:56 AM | #8 | |
Rep 10,193
Im on 91 in Cali.
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black Last edited by Vic55; 09-07-2021 at 11:03 AM.. |
r33_RGSport13043.50 |
09-07-2021, 11:35 AM | #9 |
Rep 494
Throttle closures cannot be felt guys. Its only important if youre trying to exceed stock torque limits (like 600-620+ tq) with a piggy back without changing the torque limits via software recalibration. You cant just target boost to the moon without having safeties unless you remove them
09-07-2021, 11:48 AM | #10 |
Rep 924
Im not taking the whole harness off for service... Ill just pull the controller.
2023 F90 M5
09-07-2021, 11:59 AM | #11 |
Rep 263
09-07-2021, 12:02 PM | #12 |
Rep 924
Theres a plug that goes in where the controller would be to shunt it. It goes into mode "Not there" since its not connected...Remember you're not programming anything, you're just altering the input/output signals of the sensors to fool the stock ECU into applying more boost, fuel pressure, etc..
2023 F90 M5
09-07-2021, 12:19 PM | #13 | |
Rep 10,193
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
09-07-2021, 12:21 PM | #14 | |
Rep 10,193
Its right in front of their eyes. Then the reinstall took about the same time... peace of mind.
09-07-2021, 12:23 PM | #15 | ||
Rep 924
That sensor under the intake was a PITA for me going in
2023 F90 M5
09-07-2021, 12:30 PM | #16 |
Rep 263
To facilitate removal of the system if needed, would adding something like this to extend the intake sensor cable help? I know that this is not the correct cable but only for illustration. https://www.ebay.com/itm/184032965131
09-07-2021, 12:39 PM | #17 | |
Rep 10,193
I have good tools--- I removed the airbox on the right and its just unique angles from there.
09-07-2021, 01:06 PM | #18 |
Rep 263
09-07-2021, 01:22 PM | #19 | |
Rep 10,193
its removing the box thats key after you remove the strut brace. I just used a very small flat head driver to pop the sensor locking pin out and free the open the plug connection. Then just plug the RC in and push the pins in. Its a bit tedious so a nice light or flash light helps. Its still nowhere near as easy as my M8 which I can remove and install in under 4 to 5 minutes (like the F90) as the S63 boost sensor and intake are simply located.
09-07-2021, 02:09 PM | #20 |
Rep 924
Its getting two hands back in there to make the connection is where I struggled for about 20 mins. It was also 98 degrees in the garage at the time
2023 F90 M5
09-07-2021, 02:10 PM | #21 | |
Rep 10,193
The drip of sweat dont help Ill bet. I did my removal and reinstall at 7am.
09-07-2021, 02:14 PM | #22 |
Rep 924
I just did a pull for shits and Giggles. Timed it with lap timer. Map 7 in 96 degree north texas afternoon heat on warm tires.
My car is RWD. Launch control off 0-60 3.56s 0-100 7.36s See my timing shots. This is a fair improvement over stock which was 0-60 3.81s 0-100 8.04s Video here https://youtube.com/shorts/UJt5fwZLsxk?feature=share
2023 F90 M5
