09-09-2021, 03:20 PM | #1 |
Rep 253
Cheap rear brake pads for G80
Guys for anyone that is looking, I just replaced my G82 rear brake pads with these and they work find! Beats paying $400 at the dealer!
Also i noticed that my wife's 2021 X5 40i with sport brakes have the exact same rear brake calipers as my M4 so I assume the X5 rear pads are also a direct fit! Anyways, I got mine from RockAuto, part number is PAGID 355014361 Oh, and for the electronic parking brake, just disconnect it and run a couple of wires with any 5-12 volt battery to retract the motor... then just use a brake pad spreader or something similar to push the piston back in, don't forget to open your brake fluid container before! The whole procedure took me 30 minutes to replace rear pads on both sides... have fun! Last edited by av.7447; 09-09-2021 at 03:26 PM.. |
09-09-2021, 07:35 PM | #2 |
Rep 924
$68 bucks on amazon.
$89 for blue stuff ebcs.. You decide
2023 F90 M5
Retired - 2021 G82, 2019 440xi, 2020 X7, 2019 X5, 2013 F10, 2010 F10 |
09-09-2021, 08:18 PM | #3 |
Rep 253
09-09-2021, 08:46 PM | #4 | |
Rep 924
Took 4 days
2023 F90 M5
09-09-2021, 11:00 PM | #6 |
Rep 7,002
Drives: 2022 DG/BLk xDrive M4C Wk 34
Why the hell does the car already need rear pads? I just gave my commuter to my son, and the pads were at 50% with 97,000 miles on the car. Hopefully I dont have to replace mine, that quick, on the CCBs.
2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou |
09-10-2021, 06:53 AM | #7 | |
Rep 924
Same as x3M
2023 F90 M5
09-10-2021, 06:55 AM | #8 |
Rep 924
Track time
2023 F90 M5
Limegrntaln13559.00 |
09-10-2021, 08:51 AM | #9 |
Rep 7,002
Ok, that makes more sense.
YT: G Dubyou |
09-10-2021, 12:21 PM | #10 |
Rep 83
Thanks for this! Super encouraging!
Any chance you can share a picture of the wire setup to reverse the parking brake? Does it work normally when you put it back together or do you have to hit it with the battery again after the new pads are installed? |
09-10-2021, 02:16 PM | #11 | |
Rep 924
Brake will readjust automatically
2023 F90 M5
09-10-2021, 03:12 PM | #12 | |
Track Rat
1763
Rep 404
The EBC Bluestuff rears (DP52089NDX) are now being used on the G80/82. Price is around $100. Front pads for these cars (DP52454NDX) are also now available at $336. I have not used EBC pads previously but I have a set in my garage which I will install in about a month when I use up my remaining sets of BMW OEM rears. It just seems logical and worth a try that they will wear better than the OEM's. In fact, for those who are thinking of replacing their rear pads with the older less expensive OEM pads, why not try the EBC Bluestuff rears instead for about the same price. There is a good chance it is a better and more durable product.
IOMG // Full Tartufo Leather // MP HAS // Vorshlag Camber Plates // SS Brake Lines
09-10-2021, 04:16 PM | #13 | |
Rep 1,290
Pacific Raceways Turn 2 requires braking downhill from 155mph to about 60-65mph, Turn 3a braking downhill from about 117mph to about 40mph, Turn 5a braking from about 123mph to about 70mph. Those are about the heaviest braking zones for me. It's only you and a couple of other guys here, from what I can tell, that are reporting this excessive wear on the rear pad. So either you guys are extremely advanced and fast drivers that are somehow able to wear out an entire pad per trackday or maybe it's possible that some cars might have some faulty rear brake caliper calibration from factory that puts unnecessary excessive wear on the rear pad. Or maybe it's possible that the rear pad compound that BMW ultimately chose is garbage for very fast drivers on tracks that are very hard on the brakes.
2024 BMW M4 Competition XDrive - Tanzanite Blue/Kyalami Orange - AST HAS - RaceChip
09-11-2021, 06:47 AM | #14 | ||
BimmerPost Supporting Vendor
13038
Rep 18,749
09-11-2021, 09:08 AM | #15 |
Track Rat
1763
Rep 404
Not mine. DSC / MDM / TC all off. Have driven this way for years. And Lewis Hamilton is not worried about me either. I just drive them as I find them. Speaking of which..qualifying at Monza is on in 10 minutes..gotta go.
09-11-2021, 09:42 AM | #16 |
Rep 5,262
Maybe you need to stop braking and accelerate more
09-11-2021, 10:48 AM | #17 |
Track Rat
1763
Rep 404
Races are not won in the straights...they are won in the turns.
09-11-2021, 05:03 PM | #19 | |
Rep 924
No parking brake warnings and everything worked flawlessly. Tested parking brake and auto hold, no issues. Thank you @av.7447
2023 F90 M5
DocWeatherington2943.50 |
09-11-2021, 07:12 PM | #20 |
Rep 924
See my earlier post. Retract it fully and reinstall..car automatically readjusted
2023 F90 M5
09-15-2021, 06:26 PM | #22 | |
Rep 253
As far as the compound of the rear break pads, believe me you have the most street compound BMW can find and will not make much noticeable difference if any between the X5 and M3/M4 rear pads... Personally I cant wait for hawk hp plus to be out with their pads for the M4! |
