09-12-2021, 02:01 AM | #1 |
Rep 30
Minimum offset for 225/45/18?
Hey guys, just wanted a quick check to make sure these fit.
I did some prior research on this thread and found someone using the same tires with an ET42 offset. A reply claimed this was "even better" than ET45, so would that mean ET40 is guaranteed to fit? Here are the details of what I want to put on my m235i. Euro Design Tech Matte Black 18X8 5x120 et40 CB64.1 Also the bore is 64.1 does that mean I can not fit them on my car? |
09-12-2021, 12:06 PM | #2 |
Car Geek
3727
Rep 3,632
Bore has to be 72.56 (or larger with hubcentric rings).
5x120 with 64.1 bore would typically be a wheel to fit a Honda/Acura SUV. |
wantam235i4.00 |
09-12-2021, 01:19 PM | #3 | |
Rep 30
Considering I got a correct bore size, what is the offset I would need for the fit? |
09-12-2021, 01:57 PM | #4 |
Car Geek
3727
Rep 3,632
For a 225/40-18 front tyre and stock camber, ET38 to 45 would be an appropriate offset range with a 18x8 wheel, with ET42 being close to optimum.
wantam235i4.00 |
09-12-2021, 05:55 PM | #5 | |
Rep 30
EDIT: found your reply on this thread https://www.2addicts.com/forums/show....php?t=1475699 and will be using it as basis to run 225/45/18 on 18x8 ET45 rims. Thanks Last edited by wantam235i; 09-14-2021 at 01:19 AM.. |
