09-15-2021, 07:17 PM | #1 |
Rep 1,022
Found this gem in my rear run flat. Carefully remove with some pliers? Just a flesh wound? Business as usual after I remove or take it in to get inspected?
… yes, I know I need to clean the car |
09-15-2021, 08:07 PM | #2 |
Rep 5,355
I think you lucked out. Perhaps some plug repair cement in the hole just because you can and call it a day.
dmanb2b2134.00 Paultattoo190.50 |
09-15-2021, 08:10 PM | #3 |
Rep 1,022
09-15-2021, 08:22 PM | #4 |
Rep 4,246
Oh Lordy the brake dust!
Haha, just kidding mate. Looks like you lucked out, pull out slowly and check for leak with soapy water.
Wanderer73673.50 |
09-16-2021, 12:28 AM | #6 |
Rep 80
It is run flat? I was told I’d need to get new one if it got punctured but they were able to fix it with a rubber plug thingy and I drove without any issues since then.
09-18-2021, 10:12 AM | #9 |
Rep 1,022
I removed it, and from what I can tell, it was just a surface wound through the tread but easily could have done worse. Seems to be holding pressure, but I'm going to have someone look at it regardless.
