E90 Fuel Tank
04-28-2006, 07:48 AM | #1 |
Rep 399
Drives: 2023 BMW i4 eDrive40
E90 Fuel Tank
I am curious about the fuel capacity of the E90. In the owners manual on page 60, BMW states the capacity as 15.9 gals/60 liters . On page 106 and 151, it says the capacity is 16.1gals/61 liters.
I have noted that the Consumer Reports (May,2006) article and the Road and Track (March 2006) article show a 15.9 gals/60 liters capacity. I have also been out on the various BMW web sites around the world and the capacity varies from 60liters/15.9gals to 63liters/16.6 gals. I would think that BMW would make one size tank for the E90. Any ideas? wallyf |
04-28-2006, 10:26 AM | #3 | |
Rep 369
Well I normally run mine till when I have about 8 miles or less left on the range and the gauge shows that it almost empty. At the pumps I have seen between 16.1 to16.3 gallons to fill my tank. So just like you, I am not sure of what to believe. Could be that BMW as usual is been conservative in that regards. My other guess, could be that tank size is the same but depending the atmospheric temperature and pressure you can have a varying volume of Petrol at the pump. |
04-28-2006, 10:44 AM | #4 |
Rep 297
The tank capacity is one thing, but the fuel in the filler pipe makes up for a bit of what you fuel up, as well as the fuel left in U-bend of the hose at the pump or whatever back channels after the nozzle goes *clunk*
So what you pump out is not necessarily in the tank... for e.g - a 62 litre fill up is probably 60 tank, 1 filler pipe and 1 U-bend / back-channel - it won't be those exact ratios, but you get the point That's all I can come up with to explain the fluctuation in capacity levels - or as mentioned above, the density of the fuel based on temperature, etc - that can be a contributing factor too. Also, if you're car is leaning, a little bit of the tank stays empty - all of these possible factors explain the differences By the way, while we are on the subject of fuel... is it not ill-advised to let your tank run so low? |
04-28-2006, 10:52 AM | #5 | |
Rep 256
04-28-2006, 10:59 AM | #6 | |
Rep 423
04-28-2006, 11:26 AM | #7 |
Rep 10,411
where is fleet he will know
2010 AW e90 328i: 6 speed, Black Leather, Dark Wood trim, ZPP, ZCW, ZVP,ZSP, Nav, Xenon
BMW Performance CF Rear spolier and Gloss black grills 2008 Candy White MKV GTI 2.0T 6 Speed Manul Gone 2008 AW X3 3.0si: 6 speed Returned 2006 AW e90 330i: 6 speed Dinan Stage 1 Returned |
04-28-2006, 11:44 AM | #8 |
Rep 10,185
Tech manuals say 60L ( 15.9Gallons acording to 1st post )
As said before, the slight difference would be what the filling neck holds, with 1 litre sounding about right For interest, the USA cars have a different tank from the Euro cars. The Euro tank is listed as holding 2 litres more ( about 0.53 gallons more )
BMW if you are reading, I need a job, Please. |
04-28-2006, 12:11 PM | #9 |
Rep 776
Drives: 330i rec'd 2/17/06
Yet another mystery solved by Fleet.
JB | BBS CHs | Blacklines | HO40 | ACS Rep Roof Spoiler | H&R Sport | Hartge Rep Lip | OEM Strut Bar | M-Tech Rear
09-21-2006, 11:16 PM | #12 |
Rep 921
So my E90 330 (Feb 2006 built) manual claims that the fuel tank capacity
is 16.1 US gallons including 2.1 reserve. The OBC was saying that I had 10 more miles worth of gas. With the worse estimate this is about 0.3 of a gallon inside the tank. I went to the gas station and filled up. The tank took in 17.29 US gallons (yes it's not an error and the gas station is not a crooked one since it's owned by a friend). Adding to that the 0.3 already in the tank we have roughly 17.6 gallons of fuel in the tank. Now from the capacity claimed by BMW this is off by ~1.5 gallons which is so much that it can not be explained easily by the filler pipe, temperature etc. And mind you I didn't have the patience to take the gas all the way to the top to be able to see it at the top of the filler pipe. So I could have put more gas. Possibly not much but definitely more. So I don't think Fleet or anyone else has solved the mystery yet or given a reasonable explanation as to why we see such discrepancies especially of this size. Thx, sc.- |
09-21-2006, 11:29 PM | #13 |
Powered By 36DD
341
Rep 7,369
somehow i thought the tank was 18.9 gallons.....my bad.
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
09-21-2006, 11:39 PM | #14 |
chichen
Rep 233
most cars have a reserve area that holds usually 1 or 2 gallons of fuel...just so you don't run out of gas....
my b5..would chime when it hit near empty...when it hit empty..it would give off a second chime and the gas meter would actually go back up....letting me know that i'm on reserve...the car would stop and run out gas exactly when it hit empty the 2nd time....wow..if vw can be this accurate with the gas meter...why can't bmw or mercedez do this? anybody with portable gas tank want to experiment and let us know?..hehehe |
09-22-2006, 12:04 AM | #16 |
I AM the 12th. Emom
48
Rep 1,007
also keep in mind that the fuel expands a little when its very hot out...
could be enough to cause variable readings..
e92, 335i SG/ Coral. 6m, LSD,
09-22-2006, 03:04 AM | #18 | |
Rep 547
Drives: 335 I Coupe
335i, 6MT, montego blue, jade grey, grey poplar, anthracite headliner, style 230 rims, short shifter
09-22-2006, 05:01 AM | #19 | |
Rep 364
I usually don't go below 1/4 full, just stop at the first Shell station for V-power 99 RON. If I let it go any lower, I might not pass a garage in time. In regard to an earlier post, you don't pay for the fuel in the pump hose, only what comes out of the nossle, so the gallons dispensed won't include that fuel in the hose. Some pumps trip early and some wait till fuel almost spurts out the filler cap, so it's difficult to get an accurate figure.
330i M-sport SG + black leather :rocks:
09-22-2006, 05:48 AM | #20 | |
Rep 19,368
I should add that I've never once run the car completely out of gas, which would be bad for the pump obviously. |
09-22-2006, 06:01 AM | #21 | |
Rep 364
Do you know the distance to every garage wherever you happen to be? What if you get to -- miles and the next garage is 50 miles away? Or one that only has low grade fuel? Why have all the risks when you have paid for a car with a display to help you avoid them all? Sounds like you are just asking for trouble. Why not disconnect your speedo, you don't need it - just guess how fast you are going.
09-22-2006, 07:32 AM | #22 | ||
Rep 19,368
Nah actually, I do it because of what I said above - I figure it minimizes the chance that I'll end up with crap at the bottom of the tank. Quote:
