N54 to N55 Swap
09-20-2021, 08:41 AM | #1 |
Rep 4
N54 to N55 Swap
Hello Fellow E9X owners.
Have any of you done a n54 to n55 swap. I bought my car for 1k with a supposedly seized engine. With little effort I got the car started but I now am hearing a knocking noise. I have already checked the power steering pump pulley and have ruled that out as a possible issue. The engine had lots of oil when I started that. If worst comes to worst, once I pull the motor and asses if I have thrown a rod. I will most likely swap in another motor as the price to refinish the head and buy a Piston and rod setup will cost almost the same price as a sub 100k kilometre n54 or n55. If anyone has done the swap. What was necessary. Whether it has a different ecu or motor mounts will all play an role in my decision. Thanks for taking you time to read through this. Thanks |
09-20-2021, 09:31 AM | #2 |
Rep 384
I would first verify that it is indeed the motor, pull the belt off and see if it goes away.
If you do verify it is the motor and really want to endeavor, the mounting points will be the same, they never changed the subframe. So it will fit in the car. What are your plans for a turbo? Of course you'll probably have to use an n55 turbo because there is only one oil/coolant feed and oil drain, and the DME is also different (MEVD70 vs MSD80/81) so prepare to find one of those. If you can verify that the new ECU will be able to communicate with some of the older modules (which it probably can), and you really want to do it, I think it'll work (get an e9x n55 if you wanna be safe). Don't expect everything to go smoothly though, you may find small incompatibilities. But in my opinion if you want an N55, it will be much easier and probably cheaper to part out this car or sell it, and buy an N55 car. That's what I would do. Or find a used N54 from car-part or the likes and throw it in. |
TheBlownE920.00 Luper5258.50 |
09-20-2021, 09:47 AM | #3 | |
Rep 4
09-20-2021, 11:04 AM | #4 |
Rep 385
You're trading one set of problems for another going to N55. I'd either put another N54 in there, or most likely sell the car. The resale value of these cars is not high, the level of effort to change engine type will be high, so the only way I'd do a non-native swap is if it holds some emotional appeal (i.e. LS swap, something cool like that). Otherwise just sell the car and buy something more to your liking.
2007 E90, 6MT, VRSF 7" FMIC, RR DP's, Vargas Stage 2+ (19t unclipped), CP-e Charge Pipe/Tial BOV, BMS DCI, Fuel-it! Stg 2 LPFP, E66, 118k+ miles Brentuned
09-20-2021, 11:19 AM | #5 | |
Rep 4
09-21-2021, 12:23 AM | #6 |
Rep 384
E series N55 is no more reliable than the N54 really, same injectors, same HPFP, same water pump, turbo problems, vacuum issues. It's not much of a difference unless you are looking at F chassis EWG cars. Good luck, keep us updated
TheBlownE920.00 |
09-21-2021, 02:17 AM | #7 | |
Rep 3,680
Throw in a used N54 with a warranty and call it a day. |
11-15-2021, 09:05 AM | #8 | |||
Rep 4
11-15-2021, 12:19 PM | #9 |
Rep 1,165
Drives: 09 E92 335i 6MT
Replace any and everything you can with it out. Do rod bearings, every single gasket (valve cover, oil pan, oil filter housing, the vacuum pump seal on the front. Front and rear mains too). Get a front crank seal protector. If the injectors are index 12s, redo the seals and decouplers, if not up to you if you wanna try and ride em out for a bit but at the very least change the seals and decouplers. If it were me i'd do the water pump and thermostat as well. Check all your pulleys, if any are bad i'd just replace them all.
This is your perfect opportunity to address every common issue the N54 has with the most ease you could ever have and have an absolute blast with it. You say you got it for 1k? You have the perfect opportunity for a very fun and decently reliable 400+whp car for an incredible price. If you wanna spend the extra for some upgraded turbos (or turbo if you wanna do single), a solid 500whp with some decent overhead is totally within reach as well.
09 E92 335i 6MT / Alpine White / Coral Red / VRSF 7.5" / VRSF DCI / VRSF Catless Downpipes / VTT Charge Pipe / Turbosmart RacePort Gen V / RB OEM Billet Turbos / CD919 Custom Tune / Bilstein PSS9s
