09-25-2021, 12:14 PM | #1 |
Rep 739
H&R springs removal every season.
ok i'm a newbie when it comes to suspension stuff! I was wondering if it will harm my m3cx if you remove the aftermarket springs every winter and put back on your OEM springs and winter tires because I live in ny and Im worried about snow and ice build up and especially not using my 92k car as a snow plow.
09-25-2021, 04:35 PM | #2 | |
Rep 7,002
Drives: 2022 DG/BLk xDrive M4C Wk 34
2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou |
bimmermann88312.50 |
09-25-2021, 07:15 PM | #3 |
Rep 200
You could install a HAS kit and raise it up for winter too.
09-25-2021, 08:00 PM | #4 |
Rep 1,385
Is the 20/30mm going to make that much difference!?
I'm in NY also, if there is deep snow on the ground I'm not going anywhere but usually the roads have been swept up by the sanitation guys after a few hours. The bigger concern for me would be winter tires. I don't think the ride height will be that significant? |
JTO245276.00 |
09-25-2021, 08:05 PM | #5 | |
Rep 739
09-25-2021, 08:08 PM | #6 | ||
Rep 1,385
I don't need to drive anywhere really so will probably avoid the worst days. I'm still not sure if the height will help that much if it's a really bad day? |
09-25-2021, 11:08 PM | #7 |
Beware of cheap bait!
711
Rep 715
You're better off just leaving it stock or dealing with a lowered car in the winter. You could get H&R VTF or KW HAS Instead but you really should still align it anytime ride height changes... And even then the rear springs need to come apart if the new stuff is the same as F80
09-26-2021, 04:27 PM | #8 |
BimmerPost Supporting Vendor
13041
Rep 18,751
Better off selling it and buy F97 X3M or F98 X4M.
As fast, better ground clearance.
09-26-2021, 04:33 PM | #9 |
Rep 739
r33_RGSport13040.50 |
