What is the rootcause of engine damage?
09-26-2021, 03:16 AM | #1 |
Rep 16
Hi,
I had a persistent cyl #4, which was diagnosed broken piston rings by an indy shop. I pulled the head but did not see any cylinder wall damages. On the other side, i have noticed the cyl 4 is much cleaner than the other ones And i have severe damages in the camshaft lobes on same cyl. What do you think happened? |
09-26-2021, 09:40 AM | #2 | |
Rep 2,287
100% valve train related and your rings are still good. |
09-26-2021, 10:28 AM | #3 |
Rep 1,165
Drives: 09 E92 335i 6MT
Cleaner makes me think leaky injector washing the cylinder? Dunno. I've never torn down anything other than a lawnmower lol
09 E92 335i 6MT / Alpine White / Coral Red / VRSF 7.5" / VRSF DCI / VRSF Catless Downpipes / VTT Charge Pipe / Turbosmart RacePort Gen V / RB OEM Billet Turbos / CD919 Custom Tune / Bilstein PSS9s
ky0u1068.50 |
09-28-2021, 11:36 AM | #5 |
Rep 947
Drives: e92 335i, f22 m235i, e30 325is
+1 on injectors based on the cylinder cleanliness you mentioned
09-28-2021, 02:16 PM | #6 |
Rep 498
Even if cyl 4 injector was leaking how would that correlate to the cam damage? Wouldn't it be more that the cam was worn which was making it run rich washing out the cylinder
09-28-2021, 02:18 PM | #7 | |
Rep 1,165
I know early on, BMW's original procedure for cleaning the intake valves was complete removal of the head and they would do a full cleaning of it.
09-28-2021, 04:11 PM | #8 |
Rep 143
It's a closed deck, what boost and power this engine endured?
I'm also in the camp of leaky injector and the lobe damage could be caused by hydro-locking maybe on startup? There should be severe petrol smell when starting the car as if running very rich. |
Dave92N54530.00 AlpineBoost3927.50 |
09-28-2021, 06:44 PM | #9 | |
Rep 2,287
I'd really like to see the valves and springs. Could the rings be intact and the compression loss was valve train related. Need more pictures. |
lightmanek116.50 |
09-28-2021, 07:56 PM | #10 |
Rep 1,165
Wow, didn't even see the closed deck. Adds plenty other possibilities, like what may have happened with that cylinder when building?
lightmanek116.50 |
09-29-2021, 08:44 AM | #11 | |
Rep 2,028
Looks like the roller failed and wore into the cam based on the pics. The pitting seems to be common on BMW cams but the pitting in the pictures does look like more than normal. The roller does look like it ate into the cam lobe though. Burning oil on that cylinder can cause it to actually be cleaner than the rest. I would not rule out a bad piston/ring. Pull it out and check... But usually the oil pushing up past the rings would leave a more specific pattern on the piston. Last edited by bbnks2; 09-29-2021 at 08:49 AM.. |
Dave92N54530.00 lightmanek116.50 |
09-29-2021, 09:44 AM | #12 |
Rep 209
Did you already remove the oil and the pan? If not, collect some oil and send it in for analysis. That will give you a good idea of how much fuel is in your oil.
2008 335xi - JB5 ISO e50, VFSR catless DP, DCI, VFSR FMIC. Fuel it stage 1, VMR V710s. 407/446 rwhp/rwtq.
2004 Cobra - Basic bolt ons with a tune. 450rwhp/rwtq450. Port coming soon. 2013 X5 50i - muffler delete, xHP tune, ESS tune on the way. 2016 Mustang GT Roush Phase 2 with VMP 767 HP kit. |
09-30-2021, 07:54 AM | #14 | |
Rep 16
Correct, it's not a closed gate. Head gasket is still on. It was a stock engine; no massive horse power. Oil analysis: i replaced the oil 200 miles ago, so that will probably be inconclusive. The bottom end seems in good shape, usually rod bearing suffer first from oil dilution with gas. It remains a mystery |
09-30-2021, 11:31 AM | #15 |
Rep 1,165
This is what a stock N54 block looks like. That is an open deck. What you're showing here in these photos is not an open deck. Your photos look very similar to the motiv closed deck motors (second photo).
09-30-2021, 11:47 AM | #16 |
Rep 3,732
The head gasket is still on the block.....that's why it looks like a closed deck.
09-30-2021, 11:49 AM | #17 | |
Rep 1,165
09-30-2021, 03:58 PM | #18 |
Rep 143
Haha, I did see pictures in a hurry on my mobile and didn't spot the gasket either ... 😅
Maybe because I have closed deck I automatically assumed this one is too. Now looking at the cam picture I see the damage and have no idea how this could happen. |
