335i throttle lag/ knotch
10-01-2021, 03:47 PM | #1 |
Rep 204
Hi all
Fairly new to the N54 so was hoping youse could help I've got a 07 72k mile MHD stage 2+ FBO 335i and I've noticed that when the throttle pedal is pressed and held to say 20% the power will be there as usual but then all of a sudden it feels as if I've floored the throttle pedal and there's a load more power even when the throttle remains at 20% and I don't move my foot. Another way of putting it feels like I've pressed the accelerator to 20%, held it there then someone has flipped an imaginary nos switch and the power increases significantly. Does anyone have any ideas? I should add this isn't turbo lag I am 100% certain of that as the rpm's are too low and it's sudden. Also it is due to get a leaky injector replaced… could it be this? Appreciate any help Thanks |
10-01-2021, 07:13 PM | #2 | |
Rep 972
If you are not experiencing any other issues like extra boost lag then these are probably the culprit. They are pretty cheap on fcp. I would replace both those and all vacuum lines if you haven't already. These are normal maintenance items.
Instagram : @Bimmer_bro
