MHD Tuning experiences.
10-04-2021, 08:33 AM | #1 |
Rep 216
I've only ever used V9 on my 07 e92 with FBO including inlets and outlets. I've read MHD V5 V7 and V9 are the better OTS maps available thus far. I would like to get a sense of the pros and cons that make one better then the other. Which is best for highway, versus canyon carving versus city driving?
10-04-2021, 08:49 AM | #2 | |
Rep 972
V5 ethanol maps make the most power, but also have the most advanced timing etc. I definitely prefer version 7 over 9. V9 has a much more linear boost curve even tho it technically makes slightly more power than 7. V7 feels fastest as the boost comes on a lot more violent. I just found my car was also much happier on 7. It idled smoother and actually was way more consistent. I always found the boost on 9 to be a little all over the place. It takes 2 minutes to switch so try whatever version you like for your driving style. V7 is 100% my favourite. That's my 2 cents
Instagram : @Bimmer_bro
Supahone81.00 |
10-04-2021, 10:22 AM | #3 |
Rep 216
Thanks for your experience.
Bimmer_Bro393.00 |
10-04-2021, 12:33 PM | #6 |
Rep 3,732
It's so easy to switch maps.....just try some different ones and see what you like.
I loved the V7 tunes when running 93 fuel....and the V5 E40 maps for E40. Those V5 E40 maps are the most powerful ones MHD has. |
10-04-2021, 01:41 PM | #7 |
Rep 216
So it appears other then custom tunes v5 is well suited for E85 and V7 has more low-end power on 93. But depending on your car and driving preference you can chose between V7 or V9. Thanks for your input.
10-04-2021, 02:07 PM | #8 | |
Rep 3,732
One word of caution...if you run any of the ethanol maps, make sure you log some runs in order to make sure your LPFP is keeping up on the pressure. You don't want it dropping much under 50psi. Have fun
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
10-04-2021, 02:46 PM | #9 |
Rep 884
Only ran the E tunes and I did V5, V7, V9 and V5 was the greatest.
2013 335is - sold
2011 335d |
10-04-2021, 04:07 PM | #10 |
Slow.
3782
Rep 7,152
Drives: Single Turbo N54 on Meth!
A custom tune is small money...with inlets and outlets why not? Add some meth or E85 and the custom tune will really be worth it.
10-05-2021, 12:07 AM | #11 |
Enthusiast
92
Rep 269
You need a custom tune with inlets/outlets to maximize power. None of the mhd OTS maps are designed for FBO w/ inlets/outlets. Stage 2+ just accounts for basic FBO. With a custom tune you can probably yield 20-30whp more with I/O. OTS, maybe 5-10whp
Torgus3781.50 |
10-05-2021, 10:38 AM | #12 | |
Slow.
3782
Rep 7,152
I would add some meth for fun, should be able to crack 450whp on stock turbos with inlets/outlets/meth + 93.
10-08-2021, 03:00 AM | #13 |
Rep 760
Drives: E82 135i & F80 M3
All this talk of MHD V5's power... I wish it worked with the Flex Fuel module.
Only V8 and V9 are compatible with Flex Fuel |
