10-06-2021, 04:12 AM | #1 |
Rep 426
Steering issue?
hi guys/gals,
i am not sure where to post this and will appreciate it if the post is moved if needed. i have an odd issue. I have the G82 2021. yesterday, while driving home from work, i noticed the steering was not smooth or linear and the car was a bit difficult to handle. steering was in comfort mode. i changed to sport and having driven this and a 440i in sport mode, i didn't have the feel of a sport steering. i thought it felt more or less the same and a bit heavier to turn back to neutral. i know sport steering is stiffer but it was different. as if i had a puncture. i checked the tyres and all green 2.2 bar all over. then increased the pressure to 2.3 and no change. i wasn't able to rest at home. i thought, is it all in my head? then i drove around and felt the same. at times heavier to turn left, a bit lighter towards the right side. when steering is back to neutral, and driving straight, the car feels heavier to maneuver. the car is a bit of an effort to drive now and i am sure a lot more noticeable on the track. i thought i would sleep it off and when i woke up, it was still the same. any ideas or suggestions please? |
10-06-2021, 06:36 AM | #2 |
Rep 15
that doesn't sound like a problem you can get from much outside of the steering electronics. Unfortunately you may have to take a trip to the dealership if it doesn't clear itself up.
10-06-2021, 06:52 AM | #3 |
Rep 426
Thanks. I have already booked in with my local dealership for Monday. I am a bit worried that they may not see this as a problem or may dismiss it as a tyre problem although all the rubber is there as I drive like a granny. It drives like a van.
10-06-2021, 12:14 PM | #4 |
Beware of cheap bait!
711
Rep 715
Try turning off all drivers assistance and see if that helps, it will dynamically change steering effort based on lane position. I have it shut off.
10-06-2021, 01:37 PM | #5 | |
Rep 426
The steering assist was off but lane warning was on. I turned all the assists off and just had some spirited driving and I dont feel the heaviness or irregularity in the steering that much. I really hope i am not getting used to it. A tiny bit is still there but I think, if I dont concentrate on it, it wont notice it that much. Its strange because I didnt make any changes in the idrive. It was very sudden. Sat in the car after work and immediately noticed the difference. I am still going to have it looked at. An M car should be very playful and nothing should interfere with it. I felt like i was sitting back in my old 320d. Thanks again. Will see how it is in the morning. I cant sleep |
10-06-2021, 02:30 PM | #6 |
Rep 53
I remember seeing on Youtube that "What's Your Forte?" had to have his steering rack replaced due to an issue. I can't recall what exactly went wrong but it was repaired under warranty.
10-07-2021, 02:37 AM | #7 |
Rep 426
Thanks for pointing this out. I watched a few of his videos regarding this steering issue. I really hope mine is simpler to fix but who knows. Like him, I am worried but the dealer not seeing the problem. This morning, I felt there was very minimal difference between comfort and sport and sometimes I have to make more effort to steer to one direction than the other. Noticeably heavier when doing a full turn. It used to be effortless. Let's see what happens Monday. Quite unusual to happen since the car has not been driven hard at all I will feedback here.
10-18-2021, 04:49 PM | #8 |
Rep 426
Just to update. I never thought a car's steering would be so sensitive to weather and tyre temp changes. The weather in the uk can change several times a day and as it got a bit warmer, the car started behaving normal. I took it to my Bmw dealer anyway to have it checked out and no issue was found. Have been driving since then and no problems. I hope the problem was related to the tyre temperature and nothing else. Will wait and see.
