10-08-2021, 08:31 PM | #1 |
Rep 246
from 4 pots M setup to 6 pots..
Just dropped my Panamera calipers of at the CNC guy for a set of custom brackets to fit them to my 380mm ///M setup... i never liked the look of the front 4 pots..
I would have gone for the 400x36 disc but there is really no more room left in my 20" MB design KV1 wheels.. calipers are a whopping 36cm in length As soon as i get the brackets back , calipers are going in for paint and then ill post some more pics.. Last edited by Belong; 10-08-2021 at 08:44 PM.. |
10-09-2021, 11:43 AM | #2 |
Rep 1,934
Kudos. Honestly took a look at a bunch of these but getting someone to cnc a bracket is scary lol. I spent a good few weeks researching 350-380mm 6piston radial calipers from different cars. Even watch a series where someone details how to get all the correct measurements to make a custom brake adapter and then print with a 3d printer etc. Only had enough guts for powdercoating .
This will be a nice setup. I really wish someone made a bracket for the 17z/18z though. Those are so cheap to find.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
Belong560.00 |
10-09-2021, 02:01 PM | #3 |
Rep 4,554
Drives: 2015 328d xDrive
Looks amazing. Have you considered a set of LCI 2 Headlights?
NYC Bimmer259.50 |
10-09-2021, 06:15 PM | #4 | |
Rep 246
Z17/Z18 need to be completely machined ( ears machined off ) and caliper needs to be drilled... so no go!!!! CNCing a bracket is easy, not really higher science If i were you id search for a set of F10 M5 calipers, they can go very nicely with a 380 disc... i had those 6 pots before on my e60 m5 with 400x36 , but now i wanted a bigger caliper My front setup is coming up for sale when i fit the new ones.. |
10-09-2021, 06:21 PM | #5 |
Rep 246
10-16-2021, 04:30 PM | #7 |
Rep 1,934
That looks great. You should spring the extra money for some lightweight rotors.
10-16-2021, 06:38 PM | #8 | |
Rep 246
Everything is ready... tomorrow calipers of to the paintshop.. and hopefully will fit them this Friday... update next week...... Last edited by Belong; 10-16-2021 at 06:48 PM.. |
10-16-2021, 07:29 PM | #9 |
Rep 1,934
Have you had to use a different MC for these larger calipers? The piston surface area has to be significantly larger now.
10-16-2021, 08:10 PM | #10 |
Rep 246
No need to , pistons are not bigger then the 6 pots bmw comp calipers and my friend runs those with 400x36 without any single problem on a 335D F31
10-18-2021, 05:46 PM | #11 |
Rep 246
Pussiwillow522.00 jeffm8276.00 |
10-18-2021, 07:19 PM | #13 |
Rep 417
This is pretty impressive, will the master cylinder on the car be large enough to accommodate the new calipers or do you have much smaller pistons on them.
'16 M4 bone stock
'13 335ix Msport BM3 stage1 - MAD FMI - FTP CP - Bilstein B4 (SOLD) '85 635csi M30 turbo race car (SOLD) |
10-19-2021, 04:17 AM | #14 | ||
Rep 246
I even had to shave of the 4 notches that are on the caliper which gave me another 5mm of room, since the wheels i have do not very well accommodate a bbk, in my 19" 437 wheelsetup i could have easily gone for the 400mm option. That is no option with the MB KV1 wheels, so even now fitment will be very tight! Quote:
They are nothing bigger then the F10 M5 6 pots pistonwise and my friend runs that setup with 400x36 without any problems or shitty brakepedalfeel.. so that shouldnt be a single problem.. Ill update over the weekend.. |
10-19-2021, 05:58 AM | #15 | |
Rep 5,410
Drives: 2015 BMW 335i x-Drive Auto
FYI- I recall when researching BremboGT's that for wheel fitment over calipers, Brembo had a certain minimum distance that they recommended between caliper and the barrel of the wheel. It had to do with road debris not being trapped in too small of a space and potentially doing damage. I don't recall the number though. |
10-19-2021, 12:02 PM | #16 | |
Rep 246
10-19-2021, 09:18 PM | #17 |
Rep 1,934
These babies have some bite. Drove some S model 992 carreras, panameras and macan s on a roval track today for a Porsche driving experience event. You will be able to stop that wagon on a dime.
If one has wheels with good clearance, and these mounts, are there any other sticking points for getting them to fit? It would be cool if the cad was shared then
10-20-2021, 06:35 PM | #18 | |
Rep 246
Was going to fit them this Friday , but some asshole just drove into my parked car today and didnt leave a note so im done with this thing for now.. |
10-20-2021, 10:31 PM | #19 |
Rep 4,031
2012 BMW 328i E93 | Deep Sea Blue Metallic - 2015 BMW 328i F31 MSport Sports Wagon | Alpine White - BMW CCA DelVal
10-20-2021, 10:59 PM | #20 | ||
Rep 1,148
Belong560.00 |
10-24-2021, 01:18 PM | #21 | |
Rep 1,199
Why would you not share the STEP file?
Th3Walrus355.50 |
10-25-2021, 08:32 AM | #22 |
Rep 246
