XHP update
10-14-2021, 05:00 PM | #2 |
Rep 3,219
Drag race mode eliminates torque reduction altogether and increases clutch wear by 4X!
Staying in 2nd gear in stop and go traffic is nice. I've also noticed XHP have added several preset shift points (relaxed, relaxed+, sportive and sportive+) with the option to also store 3 different custom shift points. |
10-14-2021, 08:12 PM | #3 |
Rep 124
xHP really giving it all with the drag race mode. No timing drops or torque loss! This will be very hard on your clutches for sure lol. Check out this log I pulled on my 94 petrol tune. 2nd gear launch
https://datazap.me/u/johnnyb12/log-1...ata=3-16-20-26
MHD Custom Map by DocVu Tuning | Rod Sutphin Trans flash | VRSF 7.5 Race FMIC | BMS Chargepipe | VRSF DP | RB Stage Ones | RB INLETS | Fuel it stage 2 lpfp
Godzilx9.00 |
10-14-2021, 08:29 PM | #4 | |
Rep 972
I would be curious about these presets! Wonder if any of it can be changed on the fly or if you need to flash each time.
Instagram : @Bimmer_bro
10-14-2021, 11:24 PM | #5 |
Rep 91
Seems very interesting. Will have to wait and see how other peoples' transmissions hold up before I try this. Seems like it would be great for the track- lots of power loss on shifts due to the torque reduction which they seem to have removed.
10-14-2021, 11:42 PM | #6 | |
Rep 3,219
Drag race mode - this is what XHP says... |
10-14-2021, 11:44 PM | #7 | |
Rep 3,219
10-18-2021, 01:02 PM | #8 |
Rep 3,732
That looks like a cool feature....but those ZF 6HP21 transmissions are only rated at something like 250 ft/lbs of torque......most people are close to putting double that much torque through them or more.
Not sure I want to slam into each gear with no torque reduction between shifts on a transmission that's already being overloaded with more power than it's been designed for. Thanks....but I'll take the fraction of a second in 1/4mile et reduction in trade for a transmission that (hopefully) isn't going to come apart on me Seems like a good way to really tear things up......
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
10-18-2021, 07:22 PM | #9 |
Rep 911
I put a good bottle on the level of structural damages this will give to an 21.
Been in the position to conduct some thermal testing on such gearbox, this will kill them. In average your gearbox hovers around 10-15 degrees behind your engine temp, the oil in the gearbox is not doing well when overheated (once), it should be replaced after such an event because it's becomes very fast very powerless in terms of keeping your gearbox lubricated. When either your gearbox oil or your hardware is not (longer) in a good shape the wear of your gearbox will go through the roof compared to a gearbox in a good state. A bit similar with tires, when they start to wear, traction will be suboptimum, more slip, more wear.. For those who are interested, there is equipment from ZF to read out all peak events measured during the life of the box. It will for example show each moment of overheated oil temps. Information not pushed to the ECU of the car. The gearbox overheated warning is to my measures triggered way beyond safe oil temps if you consider the oil vendor temp recommendations. On the other hand, it will be damn fast :-)
BMW 335 E92 09 - Full options - DKG - MHD by Buraq - RB Next Gen - RB Inlets/Outlet - Forge Diverter Valves - AR Catless DP - Afe Intake - Helix IC - FuelIT Stage 2 LPFP - Ar Oil Cooler - PPK Water Cooler - M3 Suspension - JRZ RS1 Shocks - Eibach Pro Springs - Drexler LSD - BMW IS Exhaust - Carbon Endurance Brake Pads - Stainless Steel Brake Lines - M101 Wheels - Michelin PS2 - M-Tech Body - M-Strutbar
BMW M550i G30 2019 - BM3 |
lightmanek116.50 |
10-20-2021, 11:26 AM | #10 | |
Rep 3,219
10-20-2021, 11:36 AM | #11 |
Rep 3,732
Sorry, I was wrong. ZF rates the 6HP21 at 332 ft/lbs. I bet most FBO N54's are making 500ft/lbs or more. Not sure I want to abuse the transmission any more than I have to with crazy hard shifts and no torque reduction.....sounds like a sure fire way to kill it in a hurry.
Especially just to gain a tenth in the 1/4 mile.... |
10-20-2021, 12:06 PM | #12 | |
Rep 33
10-20-2021, 12:40 PM | #13 | |
Rep 3,732
10-20-2021, 03:59 PM | #14 | |
Rep 33
10-20-2021, 05:22 PM | #15 | |
Rep 3,219
10-20-2021, 05:23 PM | #16 | |
Rep 3,219
Doing this on a single clutch transmission like the SMG made it smoother, but on a torque converter trans it wouldn't benefit the trans in any significant way. Last edited by Saif2018; 10-20-2021 at 05:35 PM.. |
spacey_n5416.00 |
10-20-2021, 05:36 PM | #17 |
Rep 3,219
The move off from 2nd gear during traffic should be useful though, as well as the preset shift points and the ability to store custom shift maps.
10-20-2021, 05:47 PM | #18 | ||
Rep 2,287
Firstly, torque reduction is nice when you have slow soft shifts taking 500-800 milliseconds to execute. The clutches are slipping for a really long time and generating a ton of heat. As you start speeding up the shift to 200-300 milliseconds, the inertia of the rotating masses starts to become a bigger factor than the power produced by the engine. Think about the engine, flywheel and torque converter spinning at 7000 rpm and the gear shift slowing at all down to 4500RPM in a quarter second. If you have enough command in the clutches to make that shift, the stress on the rest of the drivetrain is brutal. I'd be more worried about output shafts, gears and driveshafts than wet clutches, they won't slip long enough to generate much heat. My two cents |
10-20-2021, 05:58 PM | #19 |
Rep 3,732
Yeah good point. It they do say it's going to wear the clutches 4x faster......so something has got to be causing that extra wear. I wish they would give more details instead of being so vaige about it.
What do "drag setting" actually do? Boost line pressure even more? Get rid of all torque reduction? Other things that might be going on? Those ZF transmissions are pretty complicated as far as what they can do. |
10-20-2021, 08:05 PM | #20 | |
Rep 3,219
Might be ok with a one off launch but multiple launches with 4 x clutch wear will no doubt fry them quickly but yeah other parts of the trans also likely to break as you stated. |
10-20-2021, 08:20 PM | #21 | |
Rep 3,219
10-20-2021, 09:53 PM | #22 |
Rep 3,732
Yep...So is 4 times the wear on your transmission worth a tenth in the 1/4? Not for me. Give it 6 months of guys running that "drag" option...and let's see what happens. If there are no issues with people burning up transmissions..I will give it a try.
