Clunking noise After wheel bearing replacement!
10-15-2021, 02:23 AM | #1 |
Rep 104
Did a rear wheel bearing replacement on both sides on my 09 E90 335i
Did the job, put everything back together. Backed it out the shop and had a small clunking noise coming from the driver rear. Was pretty late at night, parked the car up gonna look at it tomorrow. But just wanted to know if anybody has had this issue. Before the wheel bearings replacement never had this issue. Both axles were out which is mandatory for wheel bearing replacement and put back in correctly |
10-15-2021, 02:28 AM | #2 | |
Rep 104
10-15-2021, 11:18 PM | #3 |
Rep 189
considering you bolted everything back up correctly and no issues in drums:
when does it make the clunking noise? (straight drive, over bumper, body roll, turning, etc..) need more info, but to start, if ur rear control arm bushings were old and about to go, by lifiting car while doing the bearing job, it might of finally gave way and now you hearing it clunk (only if over bumps and body roll). ABS light: sounds like you had a bad sensor or shot bearing mag. strips before so there was ABS light on dash. if you swapped sensor and put in new bearing, and car ran for 1-3mins and then threw a ABS light, check if you installed the bearing the correct way or if seated all the way back (the mag strip is only on 1 side). also if you got cheap china bearings, the mag strip ussually an issue or none existent. |
10-15-2021, 11:25 PM | #4 | |
Rep 104
