10-18-2021, 08:07 PM | #1 |
Rep 69
Striped bolt hole on rear knuckle for upper control arm??
I heard a rattle of metal in my passenger rear. I took the tire off and found that bolt that goes through and threads into the knuckle was loose. I took the bolt out and it was missing the end like it got sheard off. I tried to thread in a new bolt and no dice.
Has this ever happened to anyone? I bought a helicoil kit and hope I can get into the tight area without pulling the knuckle off. |
10-18-2021, 10:40 PM | #2 |
Rep 64
Unfortunately, yes. Hit a big bump about 2 months ago and left rear showed extreme negative camber. Local shop diagnosed bolt holding left rear upper control arm to hub carrier had sheared. They spent a lot of time extracting it. Replaced with new bolt and aligned. Was not happy with the bill.
10-19-2021, 09:55 AM | #3 | |
Rep 69
