10-19-2021, 05:40 PM | #1 |
Rep 549
M3 lower control arm swap
Hello, I'm interested in performing the M3 LCA swap but I've read that it mainly has 2 issues. I was wondering if anybody that's made the switch could comment further. First, I read that the wheel would be pushed forward and no longer be centered inside the wheel well. However, my understanding is that this can be addressed with M3 tension struts. Does anybody have the part number for those struts? Second, did adding the extra negative camber negatively affect the tire wear?
If the part numbers for all parts required can be provided by anyone that's performed the full retrofit, that would be great. Thank you! |
10-22-2021, 02:38 AM | #2 |
Rep 383
My understanding is adding the tension strut doesn’t change the caster angle back to stock. The wheel will still sit forward. But it has enough effect to prevent the rubbing some were experiencing with their wheel/tire set ups.
Any additional camber will change tire wear. Why are you wanting to run more camber, and how much are You targeting? One other consideration has been the tie rod ends will need to be threaded pretty far out to accommodate the change and have reasonable toe-in. Have you considered camber bushings instead? |
10-22-2021, 08:27 PM | #4 | |
Rep 5,410
Drives: 2015 BMW 335i x-Drive Auto
It's a noticeable improvement in steering precision and steering feel. Easily one of the Top5 mods that I've done on my car. FOR RWD: https://www.kiesmotorsports.com/prod...8;_ss=r?aff=22 FOR XDRIVE: https://www.kiesmotorsports.com/prod...8;_ss=r?aff=22 |
alohasurftoad3132.00 |
10-24-2021, 02:17 AM | #5 | ||
Rep 549
10-24-2021, 03:14 AM | #6 | |||
Rep 5,410
10-24-2021, 05:42 AM | #7 | ||||
Rep 549
https://www.turnermotorsport.com/p-3...nstalled-arms/ |
10-24-2021, 06:33 AM | #8 | |||||
Rep 5,410
The one that I am using and recommending is custom designed and manufactured to a fraction of a thousandth of an inch. I had the opportunity to actually see mine being made on a $500k CNC before they were installed on my car. I have an xDrive and I decided to add the lower Monoball control arms for even greater control and precision to the upper Monoball control that I installed first. The Turner monoball in the link that you sent is limited. It doesn't even fit an XDrive and doesn't appear to have matching lower control arms. Hope this helps! |
djacinto402.50 |
