10-25-2021, 10:40 AM | #1 |
Rep 138
Saving heads up display settings to the profile
Anyone know how to save the heads up display settings to your profile?
For example, I prefer my heads up display at the highest allowable point, however whenever I turn off the car this doesn't save to my profile. Instead of manually adjusting every time, is there a way to save this to the profile the way everything else is saved to the driver profile? Thanks! |
10-25-2021, 11:22 AM | #2 |
Rep 332
Do you have multiple driver profiles? Is it switching to a different profile (guest) every time you turn on the car?
I faced this issue initially with other settings too and I observed that every time I was sent to the guest profile. Try configuring the profile and you should be good. Also try using the memory seat saving, once you do the changes press set and press 1 and all changes should save on your profile. Hope it helps. |
10-25-2021, 11:53 AM | #3 |
Rep 138
thanks! I will try to save it the way i save the seat setting.
So it doesn't automatically switch me to guest, it actaully keeps me on my profile when i start the car each time. It's just that when i make the manual change it doesn't register for future use. It seems like i need to click "save" or something somewhere after configuring the height. Perhaps doing the seat setting will do the trick. |
10-25-2021, 06:49 PM | #4 | |
Rep 145
2018 X3 30i / Alpine White
