10-26-2021, 03:28 PM | #1 |
Rep 374
Wheel offset for G80 M3
Guys,
What winter aftermarket wheel offset should I look for? Would this work for the M3, all around? Size (in):19 Width (in):9.5 Bolt Pattern:5 x 112 Offset (mm):48 Bore (mm):66.5 or Size (in):19 Width (in):9.5 Bolt Pattern:5 x 112 Offset (mm):38 Backspacing (in):6.75 Bore (mm):66.56 Thanks. Last edited by Mperor; 10-26-2021 at 03:55 PM.. |
10-28-2021, 12:57 PM | #2 |
Rep 2,138
Stock wheels' offset is ET20 both front and rear.
That first wheel will get tucked in more than an inch on the front with same width. It'll be awfully close to suspension components, if not impossible to fit (brake caliper clearance, etc.). Technically you could make it work with 25mm+ spacers, but of course it's not recommended. I'd look for wheels that are close in spec. |
Mperor336.00 |
10-28-2021, 06:18 PM | #3 | |
Rep 243
Buying wheels for square winter set Wheels I want are 19 x 10 I can choose offset Would the right offset for the front be 25 and the rear 15 to get close to oem set up since the oem front are 19x9.5 et20 and the rears are 20x10.5 et 20 I have a 2022 comp rwd with standard breaks Any help would be appreciated |
11-08-2021, 04:55 AM | #4 | |
Rep 2,180
Mperor336.00 |
