10-28-2021, 03:01 PM | #1 |
Rep 1,683
Wheel Spacers Recommendation
Need advice on wheel spacers.
I have never used wheel spacers on any of my cars, this will be the first time. My car is not lowered yet, but will be in the future, so whatever I buy I want it to be compatible when the vehicle is lowered. Looks like the 15mm front and 12mm rear setup seems to be the most popular option. I currently have the p-zero tires so I want the setup to be flush, no poke. Once these tires are worn out, I will be switching to Michelin PS4S. Basically whichever set of spacers I buy, I just want to buy them once and call it day. With that being said is there a particular set of spacers which you guys would recommend? I'm not too familiar with all the brands. If bolts/lug nuts are sold separately, please recommend the size as well. Is 15/12mm still the recommended setup? I've read there have been some fitment issues with going 15 on the front, if this is still a concern would it make sense to go 12mm all around? |
10-28-2021, 03:05 PM | #2 |
Rep 1,751
My car is going in on Monday for spring/spacer install. I have p zeros as well. I went with 12/10 MS spacers. From what I've read, there still will be some minor rub in full lock reverse. May need to cut a few fins inside the wheel well to avoid.
iviegatron2563.00 |
10-28-2021, 03:07 PM | #3 |
Rep 272
Anyone tried off brand spacers? It's a pretty simple product. I bought ebay spacers for my M240i for like half the price as BMS etc and ran them 3 years with 0 issues.
10-28-2021, 03:14 PM | #4 | |
BimmerPost Supporting Vendor
8265
Rep 18,849
I would recommend stepping down to the 10/12 combo unless you are prepared to do some trimming on the fender liners. The rear wheels sit inward a bit more than the fronts, which is why the staggered combo is recommended - which would be much more noticeable with the fender lips bring closer to the tires after lowering.
iviegatron2563.00 |
10-28-2021, 03:38 PM | #5 | ||
Rep 1,683
g80_rick9.00 |
10-28-2021, 03:44 PM | #6 | |
8265
Rep 18,849
Slightly, but you can keep the 12mm set you have and swap the 10mm for 15mm if you change from Pirelli to Michelin
iviegatron2563.00 |
10-28-2021, 04:12 PM | #7 |
Rep 10,193
Let me paint you a picture
Lowered on MSS with 15mm spacers square- PZeros. Pirelli runs a more stout sidewall which causes front fin rubbing in reverse after you rotate the steering wheel backing up. It causes no material damage though and you can easily shave the section its rubbing with no problem. Now here are the same 15mm spacers on my X drive (doesnt matter) but I have PS4's and no rubbing under any circumstances- I can even run 18mm up front if I choose.
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black Last edited by Vic55; 10-28-2021 at 04:32 PM.. |
10-28-2021, 04:32 PM | #8 | |
Rep 1,683
What brand spacers are you using? As Tom suggested I might go with 10mm in the front and switch to 15mm when I go with Michelin, I hate the idea of shaving anything on the car despite how minor it is. |
10-28-2021, 04:36 PM | #9 | |
Rep 10,193
No rubbing of any sort from a drive standpoint or reverse with the PS4's. When I had the PZeros the only audible issue was the half steering wheel reverse crank. I knew that there was no damage but I did see peoples' faces cringe when I was leaving a public place at times LOL. Im telling, you will never know what was shaven unlike a beard on a face hahahah. Alternatively you could use a heat gun and push the lame ass fins forward as that will work too. But over time the memory of the plastic could prevail.
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
10-28-2021, 05:02 PM | #10 | |
Rep 1,683
10-28-2021, 05:04 PM | #11 |
Rep 10,193
You will never ever see the part that is trimmed if you go 15mm and have Pirellis....
10-28-2021, 05:15 PM | #12 | |
Rep 1,751
10-28-2021, 05:17 PM | #13 |
8265
Rep 18,849
Typically, you'd want 12mm rear and 10mm front as the rear is tucked a bit more than the fronts. No rubbing with this setup.
10-29-2021, 08:08 AM | #15 |
Rep 104
If that's the case then what is prompting people to go 15mm front and 12mm rear? By what you said I would think 15s should go in the rear and 12s in the front.
10-29-2021, 11:08 AM | #16 | |
Rep 980
2008 E60 550 ? Alpine White // RPI
2011 E90 M3 Competition // Alpine White // ESS // RPI // 20" BBS LM's, blah blah 2021 G80 M3 Competition // Brooklyn Grey // KW Suspension // 12mm Spacers all around // Resonator Delete |
10-29-2021, 12:03 PM | #17 | |
8265
Rep 18,849
A bunch of variables will also come into play, such as ride height, road conditions, people in the backseat or not, driving habits, etc. so there's isn't a one-size-fits-all for everyone. But you're always welcome to contact us directly us so we can steer you in the right direction.
11-01-2021, 10:40 PM | #20 |
8265
Rep 18,849
Not an issue with the minimal sizes we're running.
bwoodahl235.00 |
03-31-2024, 12:01 PM | #21 |
Rep 24
Searched the forum and there is a lot of threads around spacers but most is about looks and tire rubb or not. Hope it is OK to cut in in this particular thread🤓
I am considering putting 11 mm H&R spacers around on my G80. I will not lower it. I get that the looks will improve, which is 👍 But I am also driving active and also sometimes fast in Germany. How will the car feel in corners and in higher speed 200 km/h+? I like how the car is handling original. Will parts be more worn, ball bearings etc? I had a 996 Turbo with spacers on many years ago, I dont know how many mm. And that car felt unstable in higher speeds, like floating around a little bit, losing the tight connection from stearingwheel to road. Any experiences around car performance with spacers? |
03-31-2024, 08:58 PM | #22 | |
Rep 34
Limegrntaln13583.00 MannyS361.50 |
