Individual AMP common fail point?
11-08-2021, 07:20 AM | #1 |
Rep 1,364
Drives: 09 E90 335i M-Sport 6MT RWD
This is for an E60/E61 although the amp (and most of the speakers) are identical to the E90 version.
I grabbed a full set up for my E61 wagon from the wrecking yard; so of course no history. I have 90% of the speakers in and was swapping the amp. When its plugged in I get nothing(no sound; just a "no gong" message on I drive and I cannot connect to it with any software. The factory Logic 7 amp works and so does the Individual amp out of my E90. On these cars the amp is set higher up so unless its a full flood, water damage is unlikely and I opened the case to look at the boards; No visible damage with corrosion or broken or broken solder joint. Just wondering if anyone knows typical parts that can fail on these units? Last edited by neilvan; 11-08-2021 at 02:56 PM.. |
11-08-2021, 02:05 PM | #2 |
Rep 13,134
Almost nobody has these.
Logic 7 amp has Led indicators for communication and functionality. On the Logic 7 amps sometimes people need to update the firmware to get them to work. Maybe you have to change the VO and code it. https://www.bimmerfest.com/threads/e...n-752.1275694/ The above is the best thread I have seen on the subject. |
11-08-2021, 02:22 PM | #3 |
Rep 1,364
Thanks!
I have changed the VO and coded it for the car; NCS expert shows "MAMP" in the listing of modules which is the Individual amp. However it cannot read it (coapi2020 IPH0009) which means no communication. I do have the later style AMP (the only version available in North America), But it was worth a shot and finding one used might be impossible because of rarity. Cost new is insane |
11-08-2021, 02:32 PM | #4 |
Rep 13,134
Can you read the other modules in your car?
Don't know how many versions there are but that shape seem unfamiliar. It see the separate power plug is that hooked up? |
11-08-2021, 02:47 PM | #5 |
Rep 2,777
did you tried to put it in e90 ?
because individual amp most plug also has additional copper section which contain a loop to power up upper processing board in amp
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
11-08-2021, 02:59 PM | #6 | ||
Rep 1,364
The picture was a generic Individual audio amp pic and the early ones had that 3rd plug. I've updated the picture with the right one (both the E60 and my E90 have just the 20 pin connector and the MOST connection) Quote:
Could you try explaining the additional copper section? I could look into that closer |
11-08-2021, 04:24 PM | #7 |
Rep 13,134
What do you mean by copper section I have no idea what you are talking about.
There is a third plug and I assume it's for direct 12 volt power as the 12 volt lines on the Logic 7 harness are pretty wimpy for that much power. I don't even have Logic 7 but all aftermarket amps that require power need beefy power lines. |
11-09-2021, 12:51 AM | #8 | |
Rep 2,777
11-09-2021, 07:30 AM | #9 | ||
Rep 1,364
11-09-2021, 10:13 AM | #10 |
Rep 13,134
11-09-2021, 05:37 PM | #11 |
Rep 1,364
Ya that was one of the threads i read. I just plugged it im and jumpered pins 1 and 2. No change.
My power and ground( the big by wires) are for sure in pin 10/20 in the 20 pin connector |
