bimmerpost/
BMW M2 and 2-Series Coupe
home
BMW 2 Series Forums (G42) G42 2-Series General Topics
      11-17-2021, 10:36 PM   #1
SKP1545
Drives: 2022 m240i
Front plates
Anyone have any front tow hook plate bracket they would recommend for the new m240i. I don't want to drill holes in my front bumper and I can't get away with not having front plates here in Chicago. They ticket very quickly here. Thx
      11-20-2021, 06:05 PM   #2
wobbly
wobbly's Avatar
Drives: 2022 BMW M240xi, 2016 VW GTI
Following, also in the Chicago area and looking for a solution. I wonder if a G30 tow hook mount would work? Honestly if it comes down to it I'm just going to zip tie it to the lower grille until something is developed.
Are you going through Knauz for your order?
      11-20-2021, 06:47 PM   #3
zzyjason
Drives: G42
Found one online.
https://www.cravenspeed.com/front-li...2020-bmw-230i/
There is also a video about it which looks solid to me. (I ordering my first BMW)
Went to find some front 2022 230i pictures, it seems fit imo
SKP1545122.50
Niko ZV118.00
      11-20-2021, 09:56 PM   #4
wobbly
wobbly's Avatar
Originally Posted by zzyjason View Post
Found one online.
Yeah if it can be confirmed that the tow hook uses the same thread/pitch, should work.
      11-20-2021, 10:18 PM   #5
SKP1545
Drives: 2022 m240i
The issue is not the thread of the hook, it's to ensure it doesn't interfere with the front parking sensors. I'll have to wait until the manufacturer confirms it. Any case, I won't have my car until Jan/feb it looks like so by then they should have something confirmed. Thanks guys.
      11-20-2021, 10:36 PM   #6
wobbly
wobbly's Avatar
EDIT: This looks promising.... https://skenebrackets.com/ still requires drilling but in a non-visible area. I imagine using some adhesion promoter would make it work with the 3M tape alone however. Going to hold out until I see what towhook options are available.
I didn't even consider that. I think one of the ones you can mount upside down would work (ex. US millworks) The sensor circled in red is likely the only one you'd need to be worried about, so the plate would need to hang upwards rather than downwards if that makes any sense. But you're right, there will probably be a solution by the time I pick mine up.
SKP1545122.50
      11-21-2021, 10:10 PM   #7
JDM_240
Drives: 2022 BMW M240i (Thundernight)
Any adjustable toe hook bracket fitted for the new m440 will work for this. Similar bumper angles to the left of the hook and proximity to a sensor on the right.
wobbly6.00
      12-02-2021, 12:16 AM   #8
dPanda
Drives: 2022 M240i
Can someone confirm that the same kit works on the 2022 m240i?
      12-03-2021, 02:28 PM   #9
64badger
Drives: 2022 M240i
I'm putting in an order for the cravenspeed mount. I'll report back with pictures when it gets here.
wobbly6.00
Dinosoar291.50
      12-06-2021, 02:34 PM   #10
64badger
Drives: 2022 M240i
Well, the one listed on their site does not fit. Working with Cravenspeed customer service to find a solution.
      12-06-2021, 02:43 PM   #11
dPanda
Drives: 2022 M240i
That sucks because the information on the web page for the M240i seems to be updated to "According to our test fitting this kit fits 2017-2022 BMW M240i, including models with xDrive models." I guess they didn't really test it thoroughly.
      12-07-2021, 10:36 AM   #12
SN1P3
SN1P3's Avatar
Drives: E92 M3 ZCP
I need a solution for this as well. I refuse to drill into my brand new front bumper, however, state requires front plate.
      12-07-2021, 11:04 AM   #13
Polot
Drives: BMW 230i, Volvo S60
They are just referring to the previous M240i, not the G42. 2017 was the year of the F22’s facelift.
You always have to be careful when new models/facelifts are released and check that the vendor is actually referring to the new one and not incorrectly
labeling old one.
jpcoop364.00
      01-22-2022, 09:59 AM   #14
Niko ZV
Niko ZV's Avatar
118
Drives: F80 M3
2015 Bmw M3  [0.00]
2001 BMW M3  [0.00]
Agreed
      01-22-2022, 05:40 PM   #15
Perets
Drives: MINI JCW, BMW 230i
I used double sided tape.
g87
