Rod knock on 50k motor
11-21-2021, 12:50 AM | #1 |
Rep 91
So went out to do some pulls for data logs to send to ken for my custom tune and bam after I finished a pull like 5 mins later after doing a third gear pull I hear this ticking coming from the motor. I am almost certain it's rod knock I have no codes expect knock sensor which I'm guessing is from the rod knock vibrations.
https://datazap.me/u/30ff/engine-blew?log=0&data=3-20 Car was running stupid rich Mods 17t eBay turbos Bmp dual walbro 450 PR Upgraded fuel line New FPR Bmp pi with aic 750cc injectors Xhp stage 3 Rb external pcv Vrsf inlets and outlets 5-40 liqui moly every 3k Full e85 Full straight pipe exhaust 7.5in intercooler |
11-21-2021, 10:21 AM | #3 |
Rep 91
11-21-2021, 05:41 PM | #6 | |
Rep 91
11-21-2021, 06:36 PM | #7 |
Rep 884
For sure its a rod knock though? Some times the injectors tick and you can see your rail pressure hanging around 2000 psi at idle and as soon as you hit the pedal the noise goes away and the rail pressure goes back down to around 600-700 psi. This has happen to my car a few times not sure what causes the rail pressure to kick up so high at idle.
2013 335is - sold
2011 335d |
11-22-2021, 12:24 AM | #8 | |
Rep 91
11-22-2021, 12:28 AM | #9 | ||
Rep 91
Here's how it sounds definitely sounds like rod knock to me but others have told me various things like evap tick, injector being loose |
11-22-2021, 12:38 AM | #10 | |||
Rep 884
2013 335is - sold
2011 335d |
11-22-2021, 12:41 AM | #11 | ||||
Rep 91
11-22-2021, 12:48 AM | #12 | |||||
Rep 884
2013 335is - sold
2011 335d |
11-22-2021, 12:53 AM | #13 | ||||||||
Rep 91
11-22-2021, 10:45 AM | #14 |
Rep 1,165
Drives: 09 E92 335i 6MT
Hmm, that audio sounds a lot more like what i've heard from a bad lifter than rod knock. Let me see if I can find any videos.
Of course, based on the log I wouldn't be surprised by rod knock. Edit: Having trouble finding a good video. Do you have a stethoscope? I'd probably start poking around with one. Of course audio direction is pretty hard to hear over a video but that sounded like it was coming from the top end to me. Edit 2: https://www.e90post.com/forums/showthread.php?t=1080990 This thread has the video I was referencing. It's pretty poor quality so in retrospect yours sounds a lot louder but :
09 E92 335i 6MT / Alpine White / Coral Red / VRSF 7.5" / VRSF DCI / VRSF Catless Downpipes / VTT Charge Pipe / Turbosmart RacePort Gen V / RB OEM Billet Turbos / CD919 Custom Tune / Bilstein PSS9s
11-22-2021, 12:37 PM | #15 | |
Rep 3,732
Also...it looks like you are getting quite a bit of timing corrections throughout the entire 4th gear pull, and your target boost was 25psi...but you were only hitting 20-21psi. Was this a base tune from Ken, or a review after he got a chance to look at things and make adjustments?
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
11-22-2021, 12:48 PM | #16 | ||
Rep 91
11-22-2021, 01:01 PM | #17 |
Rep 1,165
Hmm, curious, I'm guessing you have the AIC6 split second controller? Did ken send you anything to flash to it with the base map?
11-22-2021, 01:02 PM | #18 |
Rep 91
11-22-2021, 01:09 PM | #19 |
Rep 1,165
I am aware of this, but from what I've seen from the guys I know running PI, is that the controller should be flashed by the tuner. Unsure if this were the case for the base maps but my buddy in San Diego with Pure Hi-Flows and PI gets new flashes from his tuner just for his AIC all the time.
11-22-2021, 01:14 PM | #20 | |
Rep 91
11-22-2021, 01:25 PM | #21 | |
Rep 1,165
Just looking over the log more, are you stock TMAP?
11-22-2021, 01:28 PM | #22 | |
Rep 91
